peteb69
- 0
- Jun 30, 2011
Greenwood,
Michigan
I started my timing belt replacement this weekend, and everything was going fine until it was time to do the timing belt tensioner / pulley. I have been following the VFAQ and have searched tons of forums, but none describe what is happening to me. After I line up the timing marks and install the belt, I move on to adjust the tensioner. I turn it counterclockwise into the belt and then hand tighten (actually a little more or it won't hold. At this point, the tensioner arm is being held down to the auto tensioner by the special tool. Additionally, the pulley is positioned such that the two holes are in the 6 o'clock position. Next, I tighten down the pulley to the specified 48 NM (this is tough to do using the spanner wrench I have, it has even bent the prongs). Once tighten, the pulley holes are slightly moved (the lead hole is at maybe 7:30). Now comes the issue, once I remove the pin on the auto tensioner and back out the special tool, the auto tensioner cylinder ends up almost completely extended, no where near the specified .155". Any ideas where I am going wrong? My friend and I went nuts trying to figure this out, redoing the tension at least 6 times! My next step is to completely start over by removing the t-belt and starting from scratch. I also am going to create a tool for the pulley using the 90 degree pliers method. Any other suggestions? My friend has done a t-belt job before, but years ago. He can not recall having this much difficulty doing his t-belt. Should I be turning the pulley even further counterclockwise prior to hand tightening it (like 3:00)? I don't think I can turn it any further by hand at that step, or should I be using the special tool to adjust the pulley ccw to begin with? This is driving me nuts, I am about the to give and try and find a shop to finish the job up for me! I need to get my car going, it is my daily driver, can't afford to be replacing valves and heads either!!! I appreciate any help I can get.
