Bedicine
- 440
- 149
- Jan 3, 2022
Toronto,
ON_Canada
Hello
Hoping someone can help me identify these connectors located under the drivers side dash of a 1997 gsx. I’m also not sure of which plug goes into the side of the ectas, I don’t seem to have anything that fits it. Car is a manual and I have deleted the abs if that matters.
1st photo: side of the under dash fuse box/ectas. I don’t see a plug that fits in here.
2nd photo: this is a blue plug that’s coming from the harness which feeds the rear of the car down the drivers side door. Everything else has a home except this one.
3rd/4th photo: black plug that’s hanging down from harness that goes over the steering column. Don’t have a connector that accepts this
5th photo: this plug is attached to the plug that feeds the brake pedal switch. Looks to be the same as clutch pedal and such but I have those connected already
Thank you
Thank you
