91_LaserRs
- 0
- Feb 11, 2010
Lima,
Ohio
well my car is doing something way weird, when im trying to build boost i hit 0lbs in 1st gear and every gear after its a 8lbs the car bucks and throws a cel and wont let me rev over 5k except in 1st its 3k rpms. i cant figure out what the problem is
it started to do this after i changed out a blown head gasket, ive replaced the gasket with a cometic, new ngk plugs, diff cas, new power transistor, diff cop setup, diff ecu. i just cant seem to figure it out.
my mods include, stock ecu, .020 over pistons, acl race bearing, arp wherever i can get them. (head,rods,main,balancer) bc 272 cams, stock ic setup, external wg 10lb spring, 3in thermal exhaust, aftermarket o2 housing, 2g exhaust mani. thats all the mods i feel that i need to list to help me out with this issue
thanks
thanks
