Clutch Wont Disengage
P3Kans DSM
286
Aug 4, 2010
The Harbor, Illinois
I've replaced my clutch master and slave cylinder, along with a ss clutch line. My clutch still feels like its riding and wont disengage in 1st and 2nd gear. I've bled and bled and tested it out and still no fix. Any ideas on what to fix. TOB, clutch fork. Any help is much appreciated.
LOL i think I've encounter the most problems with clutches and tranny's on dsmtuners... hehehe.
Won't disengage??? If it won't disengage it shouldn't be able to shift into gear when the car's on.
When ever you install a new master you need to bench bleed and adjust the master cylinder to jacks video. Your clutch is dragging right now I think.
probably need to adjust the pushrod on the master fork that connects to the pedal the engagement point is ###### near the floor right now
before you do that, when did the disengage problems start? did you just replace the clutch? or did it just happen one day when you got in your car?
parked it one night. got in it the next and had no clutch pressure. replaced the master and slave now this is happening.
ive bled the system and took it out for a drive. i was in 2nd gear going 40mph at only 2k rpm's. 4th gear is hard to get into. You cant go straight back from 3rd you have to go right towards 2nd to get it to go in. Any thoughts?
I've adjusted the pedal according to the Jacks Trans video. I have no play off the floor what so ever though. I tried today just to see the catching point and as soon as i let pressure off the clutch the car dies. I also have to rev up to 3500-4k to get the car moving.
