2G 20g Setup, what should I expect? Thoughts on build?
T'd Up Steve
42
15
Nov 16, 2021
SANTA ANA, California
Hello guys,
My goal is to make 350 to the wheels on my 5 speed GSX. Check my profile for my updated mod list. i have a 1G BOV, Billet 20G TDO5H, 3inch downpipe, no cat, HI-Power 3inch exhaust, 1200 FIC Hi-z injectors, FMIC, I have all supporting mods like gauges and ECMlink v3, MBC. What should I expect out of this setup? I want to run 20psi at least, car will be daily driven and I would consider it a street build. How much power can I make on this while still being reliable on a good tune?
Thanks and let me know your thoughts.
I think you are being realistic.
Make sure the motor is healthy and ready
Make sure your tuner is trustworthy
I’d recommend adding a pump rewire and an ingersol rand EBC but not required
-Daniel
All you've done is added some lag in trade for holding higher boost to redline. If you want to run 20psi to redline, you should have got a 16g for 250 bucks. The turbo you have is for trying to scratch 30psi to redline. If you don't go for that, you have done yourself a disservice in every aspect.
I am trying to run as much boost as safely possible, and based on my research 20 is the baseline on where I should start and then slowly raise it. My main goal is to be able to boost at 25-28psi on pump gas
28psi on 91oct is going to require a bit of finesse from the tuner and you'll be running noticeably retarded timing. Then it's a matter of how much power you have to leave on the table to make power from boost, but that's what the dyno is for -- comparing runs.
You might want to look into meth injection but that has risks too.
The thing is, you have a boost goal, but that alone means little. It's only a part of the puzzle and doesn't guarantee a power threshold. I could run 25psi and make 200hp, and be taken by every 2000s Mitsubishi Mirage on the road because my timing is so rediculously retarded until I hit 7000rpm (which will also take foreverrrr) I might as well get out and walk.
If it was just to run "28psi", @Stapl3 is correct, you should have just gone with an E3 16g. It will hit those numbers happily and hit them a lot faster as well.
