Please Support Rix Racing
Street Build 9!'clipseDOHC's 1g DSM build
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Turbo Type
14b
Drivetrain
AWD
Build Type
  1. Street
K&N air filter,
Dejon intake pipe,
VRSF FMIC,
14b 7cm,
Tial 50mm BOV,
2g manifold,
MAP o2 housing,
Tial 38mm MVS WG,
Full 3" Punishment Racing exhaust,
NGK 'BR7ES',
Magnacore 8.5mm wires,
Walbro 255 lph w/ rewire,
-6 AN Fuel Lab fuel filter,
Buschur/SX AFPR,
FIC 850 injectors,
E85 (Sometimes),
Gates Racing timing belt,
CX aluminum radiator,
Three Speed Scatter Shield,
Prothane motor mount inserts,
Franks Fiberglass hood.
Mods-Engine
2.0L 4G63 6 bolt with:
HKS 264's,
Kiggly Beehives,
3g lifters,
Mitsubishi composite head gasket,
Wiseco 8.3:1 Pistons .20 over,
ACL Race bearings,
ARP head studs, main studs, and rod bolts,
BSEK.
Mods-EMS & Logging
ECMlink V3Lite on Speed Density,
Boost by Gear Solenoid,
Autometer boost, oil pressure, and volts gauges,
AEM UEGO wideband o2 gauge running narrowband simulation,
Omni 4-bar MAP sensor,
GM IAT sensor.
Mods-Drivetrain
AWD swap,
4-bolt rear end,
South Bend TZ/FE disk and SS pressure plate,
ACT Streetlite flywheel,
Split Motorsports solid shifter base bushings,
JXB Performance driveshaft bearing carriers,
Redline MTL/MT-90 in transmission and Redline Heavy Shockproof in Transfer case.
225/45R17 BFGoodrich G-Force T/A tires,
17x8" Evo VIII Enkei rims,
PowerStop Extreme Drilled and Slotted rotors,
PowerStop Z23 Evolution Sport Carbon-Fiber/Ceramic pads,
Stainless Steel Brake Lines,
KYB Struts,
Tein S springs,
Energy Suspension front control arm bushings, front sway bar bushings
Parts Wishlist
Transmission rebuild, 68HTA.
Background
I bought the car for $250 in 2003. I did a turbo swap in 2010 and and made it AWD in 2013. Along the way it has been daily driven, drag raced, autocrossed, rallycrossed, and road raced.
1/8 Mile E/T
8.697
1/8 Mile MPH
87.540
Timeslip Video Link
Watch Video
Timeslip Photo Link
Timeslip Details
Track Name : El Paso Motorplex
Nitrous : No
Fuel Used : E85
Tires : Drag Radials
Altitude : 3500
Sponsored Car : no
329.5 lb/ft
Videos
FWD donut
FWD donut in my naturally aspirated 1g.
'91 FWD DSM vs. Mustang GT
My 1991 Mitsubishi Eclipse GS (with full turbo swap) FWD, stock ECU, stock turbo, stock injectors, full interior, street tires.
15 lbs of boost, FMIC, full 3" exhaust.
Texas Mitsubishi Shootout
My 14.4 @ 99.5 MPH run at the First Annual Texas Mitsubishi Shootout at San Antonio Raceway. My best ET of the day was a 14.3 @101.1 MPH. The car is a 1991 Mitsubishi Eclipse GS FWD with a 4G63t swap. First time on the track with this setup. Stock turbo, stock injectors, stock intercooler, full interior, street tires.
Startup, Take 1
The first startup of my non-turbo to turbo swap. 2.0l 4G63t 6 bolt with Wiseco 8.3:1 forged pistons, 6 bolt rods, ACL Race bearings, ARP head, main, and rod hardware, no balance shafts.
Startup, take 1. It started up in the first crank. It ideled high at first, then started reving from about 600 rpms to 2,000 rpms. AFR was off the chart lean, switching from 17.9 to ---. CEL was on. Oil pressure good. I let it run for a while and then while I was checking things out under the hood I noticed the fuel was pouring out from the fuel inlet on the fuel rail. I shut it off right away.
Turns out it was a torn o-ring. Also the vent line on the intake pipe was open so I routed it into the catch can. This would explain the erratic idle.
2010 El Paso DSM Spring Cookout and Cruise
2011 DSM/EVO Shootout: 40 races in 12 minutes
The 19th Annual Buschur Racing DSM/EVO Shootout held Sunday, August 21, 2011 at the Summit Racing Motorsports Park in Norwalk, Ohio. The DSM/EVO Shootout is the largest DSM/EVO gathering in the world and brings together some of the fastest 4 cylinder AWD cars on the planet.
9!'clipseDOHC 2010
My 1g DSM in 2010:
Non-turbo to Turbo swap
1st Annual Texas Mitsubishi Shootout at San Antonio Raceway
Racing at El Paso Motorplex
Stock turbo, stock fuel injectors, stock intercooler, stock ECU, full interior, street tires, FWD, 14 pounds of boost.
Coming soon: Punishment Racing FMIC, DSMlink V3lite, Fuel Injector Clinic 850 cc fuel injectors, Buschur Racing TD05/6 hybrid 20g, Tial external wastegate.
TX Mitsubishi Shootout pictures taken by Nikki Deleon from texas-dsm.com.
Video thanks to my wonderful fiancee Becky!
Song is You're Going Down by Sick Puppies.
'91 FWD DSM vs. Mustang GT (In Car)
1991 DSM FWD vs. AWD
ArcticTsi ('91 AWD DSM) on the right lane and 9!'clipseDOHC ('91 FWD DSM) on the left lane.
Both 14b powered 1g DSMs.
Ironically we both trapped 102 MPH but the AWD won by 1.2 seconds.
1g FWD DSM 14b @ 15 psi 1/4 mile (In Car)
9!'clipseDOHC - 2011
My 1991 Mitsubishi Eclipse GS (T)
FWD, Stock turbo, full interior.
Best 1/4 mile ET was 13.1 @ 110 MPH on 225/50R16 Hoosier Drag Radials at the El Paso Motorplex.
Raced in the Pan AM Region SCCA Street Prepared (ESP) class on 225/45R17 BFG G-Force T/A KDWs at Cohen Stadium.
Featured on the 2012 DSMtuners Calendar (August).
Thanks to my wonderful wife for recording all of my races and supporting my hobby all year!!!
Also featured in the video: Jose (ArcticTsi), Matt (Mischif), and Jim (fwbt).
Full mod list:
Bolt-on Modifications:
K&N air filter â–« Custom cold air/Dejon intake pipe â–« VRSF FMIC â–« 14b @ 20 lbs â–« Tial 50mm BOV â–« 2g manifold â–« Megan Racing o2 housing â–« Full 3" Punishment SS exhaust â–« NGK 'BR7ES' â–« Magnacore 8.5mm wires â–« Walbro 255 lph w/ rewire â–« -6 AN Fuel Lab 3" fuel filter â–« Buschur/SX AFPR â–« FIC 850 injectors â–« E85 â–« RRE catch can â–« Gates Racing timing belt â–« CX aluminum radiator â–« Stock main fan & 12" slim fan â–« 170* thermostat â–« Three Speed Scatter Shield â–« Prothane motor mount inserts â–« Removed A/C, EGR, & CC
Engine Management:
ECMlink V3Lite on Speed Density â–« Boost by Gear Solenoid â–« Autometer boost, oil pressure, and volts gauges â–« AEM UEGO wideband o2 gauge running narrowband simulation â–« B&M fuel pressure gauge â–« Omni 4-bar MAP sensor â–« GM IAT sensor.
Engine Internals:
2.0L 4G63 6 bolt with: Wiseco 8.3:1 Pistons bored .20 over â–« ACL race bearings â–« ARP head studs, main studs, and rod bolts â–« BSEK â–« Mitsubishi composite HG â–« 3g lifters.
Drivetrain Modifications:
Quaife ATB LSD â–« Equal length half-shafts â–« South Bend TZ/FE disk and SS pressure plate â–« ACT "Streetlite" flywheel â–« Fidanza short shifter â–« Solid shifter base bushings â–« STM shifter cable bearings â–« SS clutch line â–« Redline MT-90.
Suspension Modifications:
(STREET/AUTOX) 225/45ZR17 BFGoodrich G-Force T/A KDW's on Black 17"x6.5" Dodge Avenger aluminum rims â–« (DRAG) 225/50R16 Hoosier DOT Drag Radials on 16"x6" O-Z Racing F-1 aluminum rims â–« Hawk HPS pads on Brembo slotted rotors up front â–« PowerStop Evolution pads on Brembo solid rotors in the back â–« Eibach Pro-line springs â–« KYB AGX struts â–« Polished front and rear upper strut bars â–« Energy Suspension front control arm bushings, rear track arm bushings, front sway bar bushings, and tie rod boots.
Songs: Love me Tender by Elvis, Down with the Sickness by Disturbed, and Last Man Standing by Pop Evil.
Check out my 2011 video () and look for more in 2012!
9!'clipseDOHC - 2012 Pan Am SOLO #1
My 1991 Mitsubishi Eclipse GS (T) - Street Mod Front Wheel Drive (SMF)
Pan Am Region SCCA SOLO Championship #1 - 2/26/2012 at Cohen Stadium in El Paso, TX.
Thanks to Becky and Kenny for recording all the exterior shots! Interior shots were filmed with a GoPro Hero 2.
Full mod list:
K&N air filter â–« Dejon intake pipe â–« VRSF FMIC â–« 14b 7cm @ 20 lbs â–« Tial 50mm BOV â–« 2g manifold â–« MAP o2 housing â–« Tial 38mm MVS WG â–« Full 3" Punishment exhaust â–« NGK 'BR7ES' â–« Magnacore 8.5mm wires â–« Walbro 255 lph w/ rewire â–« -6 AN Fuel Lab 3" fuel filter â–« Buschur/SX AFPR â–« FIC 850 injectors â–« E85 â–« Gates Racing timing belt â–« CX aluminum radiator â–« Three Speed Scatter Shield â–« Prothane motor mount inserts â–« Franks Fiberglass hood â–« Removed A/C, EGR, & CC.
Engine Management:
Engine Internals:
2.0L 4G63 6 bolt with: HKS 264's â–« Kiggly Beehives â–« 3g lifters â–« Mitsubishi composite HG â–« Wiseco 8.3:1 Pistons .20 over â–« ACL Race bearings â–« ARP head studs, main studs, and rod bolts â–« BSEK.
Quaife ATB LSD â–« Equal length half-shafts â–« South Bend TZ/FE disk and SS pressure plate â–« ACT "Streetlite" flywheel â–« Fidanza short shifter â–« Solid shifter base bushings â–« STM shifter cable bearings â–« Redline MT-90.
225/45ZR17 BFGoodrich G-Force T/A KDW's on Black 17"x6.5" Dodge Avenger aluminum rims â–« Hawk HPS pads on Brembo slotted rotors up front â–« PowerStop Evolution pads on Brembo solid rotors in the back â–« Stainless Steel Brake Lines â–« Eibach Pro-line springs â–« KYB AGX struts â–« Polished front and rear upper strut bars â–« Energy Suspension front control arm bushings, rear track arm bushings, & front sway bar bushings.
Song: Show Me How to Live by Audioslave
  • Like
Reactions: BOOMBOOMGSX
9!'clipseDOHC
Comments
Rating
4.00 star(s) 1 ratings
More in 1G DSM
Share this Vehicle
