Drag Race Build 1992 GSX
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Turbo Type
50-trim
Automatic
Build Type
  1. Drag Race
HAFE manifold, 73HTA FP Green w/internal gate, JMF race intake, 74mm S90 TB, PR O2 housing, 3" downpipe and exhaust, ETS intercooler, Tial BOV, FIC 1050cc injectors, rewired Walbro 450, Sparktech COP (no CDI), AEM AFPR, Fuel Lab filter, AEM fuel rail, -6AN line from filter to rail and rail to AFPR, Mishimoto radiator with shroud and slim fan, STM oil cooler kit, etc
Mods-Engine
6 bolt block, Turbo Tuff rods with ARP rob bolts, Manley pistons, Eagle crank, Kiggly girdle, ARP main studs, Buschur stage 3 6 bolt head, 1mm oversized valves, Kiggly HLA, ARP head studs, Super tech dual valve springs, HKS 272 cams, adjustable cam gears,
Mods-EMS & Logging
ECMLink v3 Full, LC2 wideband, Ominpower 4 bar MAP, GM IAT
Mods-Drivetrain
IPT restalled converter (2800 I think), Kiggly flexplate, big trans cooler, Forced4 Shift Box Plus with TCU toggle switch, Glowshift trans temp gauge
Poly front and rear subframe bushings, Maximal adj rear LCA, poly motor and trans mounts,
Nate355RS
More in 1G DSM
Share this Vehicle
