cyrez187
- 359
- 0
- Dec 12, 2003
kelowna,
B.C._Canada
i was just woundering how much tranny fluid do we need for our trannys thanks
Note: This feature currently requires accessing the site using the built-in Safari browser.
cyrez187 said:i was thinking of getting that royal purple stuff, herd its like the best
2gntmember said:ONLY USE THE MOPAR TRANNY FLUID FOR THE NVT-350 TRANSMISSION.
2gntmember said:Yeah man.. you should be happy they realized it uses special fluids.. somebody on here got their tranny fluid changed at a oil place and it almost ruined their tranny
2gntmember said:Use only the Mopar Manual Transmission fluid!!! It's specifically designed for our NVT-350 transaxle.
2gntmember said:Yep only use the mopar fluid. It says in front of the black quart bottle "Manual Transaxle Fluid".
2gntmember said:yes you need the right fluid, it is designed specifically for our synchros
pzp107 said:You must use the dealer specific tranny fluid in a black bottle. It is specifically designed for the tranny which has a few special features that no other aftermarket fluid supplier makes. ATF +4 and no other fluid on the market is good for the tranny. Each synchronizer in 2-4 gears had a paper friction surface, very specific. Other fluids will rip this completely out and mess up gear tolerances. Only the factory fluid is made for these syncros. If you had a turbo DSM than you would be able to run whatever your heart desires. But otherwise you cant.
Talon ESI-T said:The Safest fluid to use is Mopar ATF+4. That fluid has superceded the old fluid. New Venture agrees with this change. In case you didnt know, New Venture is who makes the trans for your car. New Fluid is only 8.99/QT
pzp107 said:maybe the mopar specific ATF 4 fluid will work but if you go to autozone and walmart and get there ATF 4 fluid it will not work as it does not possess the same additives.
pzp107 said:
pzp107 said:Try this one, I dont know how to upload pics to teh site cause it says failed so I used links from photobucket hopefullyt his sends you to the 3 I had time to upload.
http://s42.photobucket.com/albums/e327/pzp107/
