BANGIN4
- 8
- Feb 23, 2011
streamwood,
Illinois
My rear calipers keep locking up, I have repl them twice now. Does anyone know if the 2g rear caliper will fit on the 1g in the rear?
Thx. I figured that for the hoses. I know, that is the problem they are the "screw in" type and that is that is what's seizing. Just was not trying to buy aftermarket setup!!I'm not sure about fitment exactly but I know the lines screw in on the 1gs and use a banjo bolt on the 2gs so at the very least you'd need replacement lines to the caliper..
The 1g rear calipers are a "screw in" type, you can't compress it with a c-clamp or regular brake tool. they need to screwed in, not compressed.
That's what I was afraid of!!! Was trying not too but I guess I will have too. Thx2g caliper does not fit as ive already tried on mine. so far that i have found the only other option for us is to buy something aftermarket for the rear like stms drag brake kit.
Just remember with aftermarket ones you loose your parking brakes.
Wilwood has a selection of rear calipers with integrated cable parking brakes. I can't comment on whether or not the previously mentioned brackets are designed to use any of them, though.
https://www.wilwood.com/calipers/caliperlist?subname=combination p-brake
ok thx! I will contact him.to save some money you can also get ahold of @antilag_200 and get his brackets hes making for a wilwood setup and he will supply you with all of the part numbers through wilwood to build your own setup.
no problem buddy. im planning on getting his front and rear brackets he offers for a vented front disc and rear that will work on a 15" wheel when he gets them finalized. very nice product that he has.ok thx! I will contact him.
