Please Support STM Tuned
Please Support ExtremePSI
Partout eclipse GSX/TSI AWD Europe
qwerty5678
Mar 16, 2005
Rotterdam, Europe
I want to sell the parts of my 95 eagle talon tsi awd. I am living in the Netherlands.
Prices are in euro's:
- Slowboyracing (4g63) 7-bolt 2.3 stroker longblok, Fidanza cam gears, Wiseco pistons, eagle rods, head job done, rvs valve, titanium retainers, BC 272 Cams, ARP bolts, Multilayer stronger Cometic head gasket,new timing belt, new waterpump +/- 9.000 miles SOLD
- Stainless steel arp exhaust bolts 50
- Punishment racing HTA GT35r turbokit incl spruitstuk, 02 housing,
Tial 44mm external wastegate en aansluitingen. 1650
- Magnus Heat Barrier Intake Manifold Gasket SOLD
- 1G bigger throttlebody 62mm 60
- 1250cc Bluemaxx FIC injectors 275
- FP 4 inch Hardpipe van MAF naar turbo SOLD
- Aeromotive fuelpressure regulator with installkit 2G 125
- Walbro 255 lph fuel pump in tank 60
- Airfilter K&N 4 inch cone 60
- Apexi N1 downpipe 65
- Apexi 3 inch catbacksystem 100
- SBR Big Frontmount intercooler with 2.5" RVS piping 350
- Greddy type S Blow off valve 125
- Greddy oil catchcan incl 10-AN fittings and incl valve cover assembly150
- Magnecore 10mm sparkplubcables 70
- Injen sparkplugcover 30
- Injen fusebox cover Chrome 40
- Samco Radiator hosing kit 50
- TRE Transmission inc. 4-spider Centerdiff. Taller 1st/5th gear shotpeened and detail work 2200
- Mishimoto Radiator incl fans 150
- Sheet metal intake 250
- B&M oil cooler 100
- ACT TWIN clutch 850
- Fluidine harmonic balancer SOLD
- Bosch inline 044 with harnass 150
- FueLab "818" Complete Fuel Feed Upgrade Kit: Mitsubishi Eclipse 90-99 100
- Extreme PSI Complete Clutch Line (Slave to Master Cylinder) 40
- Nos intercooler cooler with 10lbs bottle 300
- Dynamo new (not used) 150
- Apexi RSM-meter with g-sensor 150
- Apexi AVC-R boostcontroller 350
- AVC_R air fan bezel 2G 20
- Front strutbar 30
- Brembo evo 10 350mm brakes(complete with pads and rotors) front and rear (rear rotors evo 8 and evo X) 1000
- Galant knuckles for the evo brakes 120
- Goodridge brakelines front 30
- Evo X velgen (ZWART) federal semislicks 5,5mm SOLD
- Prothane Motor Mount Inserts: Mitsubishi Eclipse 95-99 35
- Konig afterburner 19 inch velgen met pirelli p-zero nero banden 950
- Blitz style rearbumper rear lights removed 85
- xenon lights pilot 25
- GM 4bar Map sensor 40
- IAT sensor 15
- AWD swap excl trans 800
fueltank, exhaust, subframe rear, axles, driveshaft, tranfercase etc.
