VelocitàPaola
Moderator
- 5,083
- 171
- Jun 14, 2005
Ft. Lauderdale,
Florida
Yes, unless you want to pull the engine instead.that means im going to have to drop the transmission right? Because if i have to, then i have to take it to my mechanic
Note: This feature currently requires accessing the site using the built-in Safari browser.
I got a bad habit of hittin the wrong button.I'm not to good with this computer crap.Back when I got my license the only computer we had in our cars was maybe a calculator(1st car,69 charger 383 magnum)Good to hear OP.
And @ Starfish quoting himself with the same post that he posted up with (#14)
MB
GS895,did you try pullin the slinger out to see if the noise goes away?Its pretty easy!Nothings gonna jump out at you.Pull it just to see if thats where the noise is coming from.Make sure you put it back.My 1st tranny made that noise for two years,untill I swapped out the motor ,tranny combo.Now my new one also makes alittle noise when cold.
