4G63510
- 61
- 25
- Sep 6, 2021
Las Vegas,
Nevada
I've been seeing low oil pressure at idle for some time now. By low, I mean Zero at times when warm at idle. I've had sparkles, but no flakes in my oil for about 2 years, but I haven't really had any issues. Thinking I may have a worn oil pump, I swapped that out this spring when I did a new RWD oil pan and some other odds and ends. There was no change. I did check one rod bearing when I did this and I didn't see any issues. I also thought it may be a bad sensor, as I'm running an electronic oil pressure gauge, but it doesn't feel like that is the case.
Yesterday I took the car out for a short drive prepping for the Shootout and after seeing that Zero on the gauge again, it dawned on my that it may be bad oil squirters. This is a 95 block, and if I recall, it is rumored (or perhaps confirmed) that they can stick open and bleed oil pressure. This would confirm my low oil pressure in all scenarios. I used to have 80-100psi on start up and over 20psi at idle. Now it's more like 60psi cold and, as I stated, zero at idle. This was even after switching to 20w-50 Valvoline VR1.
I can investigate this, but the real question is, how to go about it? Replacing the squirters is a "crank out" procedure. Which essentially means everything is coming out except the head. I do have a spare 95 block with stock internals as well. So, do I do the bearing with the head on, or do I swap blocks all together? I assume this means I need to re-deck the head for an MLS headgasket, and along with new piston rings, that would be the only additional cost in using the spare block. It seems like it would be easier to do this work on the spare block, but is it worth it?
I'm really hoping someone can chime in soon to help me make a decision. I have the time, money, and ability to get this done before the Shootout, but a fresh install is always a crap shoot. I don't want to rush this, but I REALLY would like to make it to my first Shootout.
