tenn-gsx
- 1,269
- 24
- Apr 25, 2006
Fort Worth,
Texas
That's funny, he's getting a CEL with the stock hood but with a vented hood he doesn't? And my last post didn't make sense? Sheesh. None the less it's useless! It isn't even needed, you do it because you want to and that's all I'm saying. So what if you do want to, it's still a waste.
And there is NO hard fact from time tested and multi-tried testing that shows having a vented hood for "heat to escape" allows the car to be "quicker". Get off that.
The CEL is from having Link or some type of tuning device that turns on the cel at a given coolant temp. So lets say his is programmed to come on at 219 deg. Without the vent there was too much heat being held under the hood and Under certain conditions his car would het hotter than 219 deg turning on the CEL. Now with the vent he is allowing enough heat escape to keep his engin coolant temp BELOW his PREFERRED temp of 219. As well as that fact It is POSSIBLE that if a vent is efficient enought that it could evaccuate enough heat to help the efficiency of an engine. Therefore creating more power. I wish I could find the link to a diagram that shows the basics of how air flows over any "modern" styled car. Maybe then you would see the possible benifits of doing a mod like this. No I dont have this mod done and I dont have plans to do so any time soon. But this has proven Its self more than once to be a solid mod for somebody that is holding too much heat under the hood.
