turboAWDfanatic
- 347
- 29
- Aug 22, 2005
Colorado Springs,
Colorado
I just installed a Devil's Own meth injection kit. Before tuning for meth I wanted to test it out with just water to see that the trigger system and fail-safe that I set up is working. I flip a switch to activate the pump, it is triggered to flow by a hobbs boost pressure switch, and it works, but immediately after doing the water injection the car suddenly runs EXTREMELY lean at cruise and idle. The car barely runs and AFRs read between 18.0:1 and 21.0:1. This is after only momentarily using the water injection system. Over the course of an hour, the AFRs slowly return to normal.
Looking back, the exact same symptom showed up once after accidentally driving through a deep water puddle at a good clip during a rain storm.
I am using a speed density setup with a Zeitronix 3.5bar MAP sensor and a GM IAT. I am tuning it with TunerPro on an Ostrich chip emulator. The MAP sensor is threaded directly into the back of the intake manifold next to where the brake booster hose nipple is and the water injection nozzles are in the intercooler piping between the BOV and the throttle body. With speed density the only two major variables in what AFR you are at are the volumetric efficiency of the engine and the reading of the MAP sensor (with IAT adding a small change). With that in mind, I can only think that the surface of the MAP sensor getting wet is causing an inaccurate reading that would throw off the tune, but I contacted Crock at Zeitronix and he said that moisture getting on the sensor inside the intake manifold shouldn't cause a problem at all.
Is there anything I'm overlooking? Could something else be getting moisture on it that would have an affect on the tune? I am certain that introducing water with the meth injection setup is what's triggering the lean condition because it is very repeatable and only happens after triggering the pump to inject water.
