Please Support ExtremePSI
Anyone interested in a machined 1g engine?
ASPTech1
May 11, 2013
Jacksonville, Florida
I'm looking to sell these items around Jacksonville to avoid shipping.
Machine work done by experienced machine shop in New Jersey.
1990 4g63 engine block:
-bored 0.020" over
-balance shaft oiling holes set for eliminating shaft
-surface decked
-checked for cracks
-new freeze plugs
-hot tanked
-crankshaft cut and polished 0.25mm
-matching main and rod bearings included
1g cylinder head:
-surface decked
-new viton valve stem seals
-spring and valves installed
-vacuum checked for valve sealing
-cleaned and ready for install
1g black cover CAS
-purchased from onGreen Performance
-includes wire lead with connector
used 1g oil pan
1g water neck
1g oil filter housing
used 2g transfer case (1996 eagle talon)
I winded up going with an ATK 2g rebuild when my original engine with 205k miles walked its crank, LOL.:ohdamn:
Also considering to sell my 1996 Eagle Talon AWD..
PM me if you're interested.
Thanks
