bisoo369
- 39
- 0
- Apr 27, 2010
Glenview,
Illinois
Hey everyone i'll make this short. P.O did a 6 bolt swap in my 97 talon. Everything was wired correctly, car ran fine. I unplugged all the swap harnesses to clean the intake manifold, tried to plug them back in correctly, now the car doesn't get spark(?) or the cas isn't letting the car turn over or something. All i get is a bunch of clicks. so I unplugged all the wires and took pictures
First picture looks to be the rre swap harness? (I barely know what i'm talking about)
Second picture i'm holding the coil pack harness
Third picture is the 3 triangular harnesses with green pin locks or whatever those are. I believe one of those is ac which i've deleted.
Fourth pic is a zoomed out view of everything.
5th pic is this plastic piece on the coil pack. Its loose, maybe that's a problem?
I figured i get all this sorted, and if i still cant get it to run i'll move onto checking the plugs and wires and all that.
Car was running fine, then i took all that apart, unbolted the coil pack, fuel rail, injector harnesses/injectors, cleaned the intake manifold and switched to an afpr setup. The car is getting fuel. I also sprayed some soapy water here and there for a boost leak test. Forgive me but i can't understand this any better by reading through previous posts about this, or rre's write-up on their website.
