Please Support Morrison Fabrications
6 bolt in a 2g kiggly kit (need correct flex bolt to crank)
Cornfed4G64
215
Feb 10, 2011
Lindwood, Minnesota
So I asked around even emailed kiggly (waiting for reply) and can't get the right answer. I also have stopped at the local mitsu with no help without a part #.
So what I'm looking for are the correct flywheel/flexplate to crank bolts.
I have a g4cs 6 bolt crank in my car and the bolts I have are bottoming out and also have a 19mm socket head and not the standard 17mm. But these bolts also have enough threads on them where the 5 spd (I believe the threads falls short going through the oem spacer and kiggly flexplate.
I had everything installed correctly. Just need the part # for what I'm looking for.
The bolts I first mentioned with the 19mm socket head hit the pilot bushing so I can't torque them down properly.
Thanks in advance as I want to get to the track ASAP.
Anyone?
