1G 1G Crossmember Bolt Sizes
I have spent days trying to source the sizes of the crossmember bolts on all three beams, not to mention absolutely no luck from the dealer. Today I came across all of the bolt measurements on accident and I wanted to put them all here so you all don't have to go through what I went through to find them for your projects.
If you use CAPS, I will make it easier for you by including the catalog tags (6-digits) so you can cross reference to the bolts you need. Per the dealer, ASA was not compatible in cross referencing the CAPS catalog tags of these bolts. I will post the diagram for reference.
This thread will allow you all to easily locate the hardware from your local hardware store. This information should streamline to all 1G/GVR4 users with ease, and some 2G bolts are recycled as well. All measurements will be in M(size) x (thread pitch) x (length) format in millimeters.
IF YOU WERE TO STAND IN FRONT OF THE CAR LOOKING AT THE ENGINE BAY IN FRONT OF YOU:
LEFT VERTICAL CROSSMEMBER
32166C - MB176900 - M12X1.25X28
32166H - MU240025 - M10X1.25X75
32166F - MU240024 - M10X1.25X45
RIGHT VERTICAL CROSSMEMBER
32166G - MU240023 - M10X1.25X25
HORIZONTAL CROSSMEMBER
32168B - MB242260 - M12
32157B - MB303625 - M12
Enjoy your newfound sanity!
  • For sale S90 TB 70mm
    Purchased this month from STM. Comes with the FIAV block off plate that was already installed...
    • Bedicine
  • Wanted 1g Need 1g AC tensioner bracket
    I am in need of 1g AC tensioner bracket - looking for complete with bolts. Recently bought 92...
    • JLavetsky
    • steelcurtaindsm
    • Syclone#334
