99gst_racer
Moderator
- 11,982
- 1,556
- Apr 5, 2003
Coloma,
Michigan
The Original 1G Chromoly Crossmember
We’ve been building these since January '09 and have 150+ units being used in the field. Rest assured you’ll get a top-notch quality product and excellent customer service when buying from me. These are typically always in stock and ready to ship immediately.
Details:
These crossmembers are made of 1.500 x 0.83" normalized 4130 chrome moly tubing. All connections are fit perfectly tight and fully TIG welded using a Miller Dynasty 210DX. Crossmembers are e-coated and powdercoated cascade (low-gloss) black as a standard option. These crossmember systems bolt up in replacement of the OE crossmember with no modifications required. All crossmembers are logo’d and serial numbered.
Benefits:
* Weight savings
* Increased rigidity
* Completely eliminates bushing deflection
* Increased clearance for exhaust and IC piping
* Solid roll stop to help reduce engine roll
Fitment:
These are designed to fit M/T or A/T 91-94 1G AWD and Galant VR4 cars only. It can be made to fit a '90 model 1G though. Details HERE
Option Choice Assistance:
If your car is used strictly for drag racing and you’re looking for maximum weight savings, I’d recommend Option #1. If you road race, autocross, or spend a lot of time street driving, I’d recommend Option #3. For everyone else (drag, weekend warrior, etc), I’d recommend Option #2.
If interested, please PM me here, or e-mail me at paulvolk83 at gmail dot com.
Ordering/Pricing:
Option #1: The crossmember bar by itself. This is a great option for a budget, straight-line car. Optimal weight savings of ~18-19 lbs. $145
Order here: http://volkmetalcraft.com/product/1g-front-crossmember-system/
Option #2: The crossmember bar with k-member plates and hardware. This is by far the most popular package. Great balance between rigididy and weight savings. Great option for any street or drag car. Saves ~16 lbs. $190
Option #3: The crossmember bar, both parallel bars, and the k-member plates with hardware. This is the full kit, intended for cars that turn aggressively. Saves ~10 lbs. $315
_________________________________________________________________________________
Customer installations:
KCasGfgQ2sFwDOsGyiB_yR7agAWHu4wuDlytcQZDy4XGLANAm2KKpWxku7Wg0vfNYAb3iKM0RyP_-xKZIfA=w699-h250-no.png4.1 KB · Views: 343
