Pursuit
- 326
- 0
- Apr 3, 2007
las vegas,
Nevada
I have more parts for sale , that are not listed in here. If you looking for something let me know i might have it.
Quarter Master twin disk just got it rebuild 1000 miles ago with street Gear drive friction disks 800TQ , floater plates and , diaphragm. for 6 bolt AWD 1000$
OEM 4g63 Evo Eclipse 7 bolt 4G64 Crankshaft STD size Micro polished , hot tanked , balanced etc 400$
Evo Eclipse 7 bolt 2.3 Stroker Manley H-beam Rods and .020 Over Wiseco Pistons 9:1cr and ACL bearings all Brand New rings, wrist pins, etc. installed ready to drop in 800$
Holset HY35 Turbo Zero Shaft Play 300$
1G Custom Ross Racing Race Intake Manifold flange for Q45 TB 450$
1G 6 bolt Howard Billet I-Beam 22mm pins 1000hp+ rods brand new 800$
1G2G 280 Kelford Cams Brand new 500$
1G2G 272 Kelford Cams 500 miles on them 480$
2G SBR 3.5" Race Core Intercooler 450$
Fuelab FPR with gauge and fittings 180$
Aeromotive inline fuel filter 75$
1G set of Motor Mounts with Prothane inserts 150$
1G AWD Auto Transmission and converter come off 91k stock car 800$
1G 4 Bolt Axles LSD axles 200$
1G 3 Bolt Rear LSD Diff 3.545 , axles and cups 250$
1GB 93\94 Eagle Talon Stock Rear Bumper while no cracks 130$
1GB 93\94 Eagle Talon Stock Front Bumper while no cracks 130$
TD05 14b Turbo zero shaft play 250$
1G 390CC Turbo Injectors new used for few hundred miles 50$
1G 91\94 Turbo ECU 100$
2G New Never used 020" Turbo Pistons , piston rings ,rods and bearing 140$
4G63T 6 Bolt Short Block 500$
Greddy Type RS Blow Off valve 150$
2G GSX Apexi N1 Downpipe 200$
3.5" Aluminum Turbo intake with coupler 70$
Evo 8,9 Valve Spring And Retainers fits 1G and 2G DSMs 100$
4G63 6 Bolt bare bock 100$
4G63 98\99 7 Bolt Block 200$
4G63 7 bolt crankshaft 150$
4G63 7 Bolt Complete Rebuild Cylinder Head 300$
4G63 7 Bolt Complete Cylinder Head 200$
E85 Low Independence RC1200cc Injectors 250$
2G 95\99 Turbo Throttle body 35$
1G\2G 450cc injectors 80$
2G 95\99 Black Dashboard 80$
95\99 GST Tanabe Medalion CONCEPT G FULL 3" EXHAUST Bolt ON 500$
1G\2G 7 bolt 93\96 7 Topline Main bearing New 30$
2G\2G 93\99 Rod Bearings STD size New 30$
1G 90\92 6 Bolt Connecting Rods Set of 4 50$
2G 95\99 Rear Differential NON-LSD for 5 speed manual 150$
2G 95\99 Transmission Mount awd/fwd for manual tranny 40$
2G 95\99 Stock Upper Intercooler Piping and blow off valve 30$
2G 95\99 Turbo Mas Air flow Sensor MAF 60$
2G 95\99 Starter good working condition for Manual Tranny 35$
1G\2G Stock O2 Housing no cracks 35$
1G\2G Exhaust Manifold 40$
2G 95\99 Turbo stock Fuel Rail 10$
1G\2G Valve Springs Set 8 intake 8 exhaust 35$
1G\2G Stock Lifters in good condition set of 16 35$
1G\2G Stock camshaft intake side 45$
1G\2G Stock camshaft exhaust side 45$
1G\2G 91\99 Power Transistor IGNITION Module 40$
1G\2G Turbo Stock Cam Gears 10$ each
2G 4G63 2.0 Turbo CAM GEAR COVER 20$
2G Turbo Coil Pack 45$
1G Turbo Coil Pack 45$
1G\2G Intake Manifold 45$
1G\2G Idle Air Controller 40$
1G TPS Sensor 35$
2G 95\98 Turbo Gauge Cluster 137k miles 40$
2G A\C Bracket & Tensioner 45$
1G TPS Sensor 35$
