Making 90-91 Clear Corner Lamps
I started this project by first opening up the hood and lifting up the the headlights, It just makes the process a little easier.
In between the corner lens and the headlamp there are 2 screws seen here.
Remove the 2 screws and the corners can be removed.
Remove the 2 plugs on the back of the corner that power the lights.
The light should pop out. Repeat the process on the other side.
Once the corners are removed
Preheat Oven to 350°. Try 300 degrees First, if it doesnt work, then use 350 degrees. Also keep a close eye on them so they dont melt. Place lights in oven for approx 5 minutes to let the glue heat up and become not so sticky. Take lights out of the oven and pry front lens off of the housing. (keep oven on to stick lens back on) Be very careful with the tabs they break easily. I also used a hair dryer on high heat to remove the lens either way works.
It should look like this
The amber part just pops out very easily with a screwdriver.
Place lens back onto housing and place in oven for approx 5 minutes again. Take out of oven, And press the 2 back together.
Wallah, You now have clear corners.
Instructions for installation are the opposite of removal. :) A good idea is to use dieselboys clearing method in combination with this.
