XSPOWER O2 Dump
Now I have had pretty good luck with ebay in terms of megan racing and other products in making sure I got good quality products. Although many people disapproved of ssautochrome housings in saying they did not fit quite right and that a few modifications would be needed I was weary but a few modifications for a nice 100 dollar piece was fine with me.
So I ended up buying it to see.
When the piece came in the mail, I could definitely see it was not Megan Racing qualitty but it was relatively good quality. As you can see in the pictures, they come with huge flanges, which I always love. Next was to see if it was gonna fit right up so I got the stock o2 gasket and lined it up (one of the pictures below). It fit almost perfectly, the top hole needs to move up a millimeter as threading in the bolts to put on the 02 housing is hard without moving it up a millimeter. Took 2 minutes of work and it fit up nicely. However, what I did was to grind away part of the flange to look more like the stock one for the wastegate flange, just in case. After that, I grinded some of the edges just to make it a little smoother in the transitions. Just my preference.
Bolted right up and sounds a lot better than dumping all of my exhaust right out the o2 housing. Isnt that loud (to me). I will definitely post up any updates if the part falls apart or I have any more problems in the future. But definitely this piece is a thumbs up so far!
  • Wanted 6 bolt NT water pipe
    • chrisman287
