ALL FWD's list your fastest times and supporting mods!!!
eclipse98GST
89
Mar 12, 2004
Florissant, Missouri
Im trying to see what all the FWD DSM's are running and what mods they have, if your mods are listed in your profile just put (see profile), otherwise list them so me and others can compare.
not exactly a good tiem but ill play along
14.6 with mods being 2.5 to 3" dp, shitty cat back that is pretty much like a stock exhaust, upper and lower intercooler pipes, fipk, and running really really rich(550's + 190lph feul pump and a zeroed out afc)
Fastest? 13.722@111.30
Quickest? 13.686@108.64
Timing was pulled hard at the end of that 13.6 second run, otherwise the trap would have been a couple mph higher. I've hit a bunch of 13.6's and 13.7's between @ 109-110.
Evo16g, stock suspension, street tires, full weight, straight C16. No new numbers for the 60 trim I have now.
-T
My first ever, and fastest is 15.2@89
Mods-
Hacked air can
K&N
Air silencer removed
BCS restrictor removed
No cat
Magnaflow muffler
(Ran open o2 housing)
Autometer boost gauge
Hitting 15 psi on 93 octane gas.
-Andrew :dsm:
14.4@100MPH
3" o2 eliminator turbo back, K&N drop in filter, vr4 pump. stock everything else. clutch slipping. 14PSI
14.03 @ 104 no times with new setup
2.5" turbo back
14b
105 & 93 mix
450's
3000gt vr4 pump
fuel pressure regulator
uicp
intake pipe and K&N
20psi
1/8 mile: 9.182 @ 80.70
1/4 mile: 14.028 @ 100.61
60ft.: 2.303
Free mods
K+N air filter
2.5" downpipe
hi-flow cat
2.5" catback
MBC @ 15lbs.
92 octane (Anyone in Eau Claire, WI know where to get 93?)
everything else stock
I have a 90 Laser, it's my daily driver. It went 14.6 @ 100.5 mph with a 2.5 60' (economy tires at 35psi)
91 octane
Denso 150lph fuel pump
2.5" downpipe
2.5" hiflo cat
3" catback
KN filter
lots of little free mods.
tuned with a Pocketlogger
everything else is stock
A couple of years ago I had the following mods, and it went 12.97 @ 109 mph with a 2.09 60', and 13.1 @ 111 mph.
big 16G
Alamo sidemount
full IC piping, turbo inlet +outlet pipes
EVO O2 housing
SAFC
hacked MAF
550 injectors with raised fuel pressure
91/100 octane mix
Quaife
225/50 drag radials
TRE modded tranny
boost set at 24 psi
2.5" dp, 2.5" hiflow cat, 3" catback
G_S_X said:
pneumo the thread said for FWD :shhh:
It's OK, the Laser is FWD. My Talon is AWD. I wish the 'Car' box (< over there <) could show two cars like over at DSMTalk, but here only the primary DSM shows up. Oh well. :shrugs:
Turbo Conversion: GM MAF & Translator
EVO 3 16G turbo w/upgraded wastegate @ 17psi
Kinetic FMIC kit
N/t large t-body
HKS 264 reground cams
2G exhaust mani
2G O2 sensor housing
Rewired Stealth TT fuel pump
RC 550cc injectors
N/T tranny
And a massive boost leak out of both throttle body shaft seals.
14.04@111MPH
But I bought an AWD, so f*ck you FWD. :p
I'm hoping my car will feel this turbo's love soon :D
The fastest at the track is 15.1 a week after I bought it completely stock.
With the mods in profile and at 15psi, my turbo timer says I'm running low 13's. I think it's fairly accurate since I've raced and hung with cars that run 13's. I will hopefully get back to the track soon. :cool:
this is all great information, make sure you all post how much boost your running when you run these times.
fastest on t25 was 14.1@99mph
fastest on small 16g/fmic + fuel = 14.2@104mph on a VERY slipping clutch through 3rd/4th and on launch...
oh..btw, after i get a new clutch, im never going back to the track without slicks, its pointless
alot of guys on here have very strong fwd cars, but they run crappy times because of no traction
it should be a law with this car, it just doesnt hook up
14.408 at 96.38 on t25. and 2.29 60'. still on t25 @ 15psi. check my profile for mods. i did that with my current mods :thumb:
my buddy vimugsy on this forum ran a 14.1 @ 105 on 16psi.
Mods are: big16g, 2g mani *ported, ported stock 02, 550's, Fmic, 2g mas, act 2100, walbro 190, 3 inch exhaust and dp.
he got nooooooooooo traction of the launch, but once it hooked up.....damn it pulled.
also his motors compression is at 120 :cry:
My best to date:
8.95@83 2.2 60's on street tires
EvoIII 16g
2.5 DP
2.5 exhaust
IC pipes
Modded smic
255lph
550cc's
on 17psi
New times to come with the Rs52 and front mount on more boost.
