Please Support RTM Racing
Street Build The [Not-So] Sh*tbox
Ownership Status
Currently Own
Eagle Talon TSi AWD
Turbo Type
16g
Build Type
  1. Street
BJ aluminum intake manifold
Forced Performance 68HTA turbo (internal wastegate)
Forced Performance race exhaust manifold
JM Fabrications recirculated o2 housing
Apexi down-pipe
Thermal Research & Development exhaust
Spearco front-mount intercooler
3" GM MAF sensor
Blitz blow off valve
Hallman Pro manual boost controller
PTE 680 fuel injectors
AEM fuel pressure regulator
AEM fuel filter
Walbro 255lph fuel pump w/ braided steel lines
JM Fabrications oil catch can
JM Fabrications coolant overflow
Magnecor 8.5mm spark plug wires
NGK BPR7ES spark plugs
EGR & EVAP eliminated
Mods-Engine
Slow Boy Stage 2 Head
Ferrea +1mm valves
WEB 272/272 Stage 2 cams
Kiggly Racing HLA pressure regulator
Mods-EMS & Logging
DSMlink v3 Full
AEM UEGO wide band sensor/gauge
Stewart-Warner boost/vac gauge
B&M fuel pressure gauge
Autometer oil pressure gauge
Mods-Drivetrain
ACT 2600 clutch kit
Symborski short shift kit
4-bolt LSD rear
KYB AGX gas shocks
H&R springs
Enkei Evolution 8 wheels
Bridgestone Potenza Pole Position tires
3000GT VR4 front 4 piston calipers
Parts Wishlist
PTE 1200cc fuel injectors
AEM high volume fuel rail
Energy suspension bushing kit
RM Racing rear sway bar
Megan Racing front strut brace
Wilwood Dynalite/Dynapro brake calipers w/ braided steel lines
Mishimoto radiator
Background
The goal is to get into 10 sec 1/4mi times, and do it maintaining street drivability and a relatively sleeper-like appearance.
do7d
Rating
5.00 star(s) 1 ratings
More in 1G DSM
Share this Vehicle
