BadManGSX's Eclipse GSX
Mitsubishi Eclipse GSX
ERL performance t3 manifold, Precision BB 6262 t3 .82ar, tial 44mm wastegate, ID 2000 injectors, Driven Innovations Intake Mani, Wilson 70mm billet TB, FFTEC isc adapter, magnus heat barrier int. gasket, full blown dual walbro 255lph-hp pumps re-wired, prothane mounts, Gates kevlar timing belt, tial Q BOV, SBR Race FMIC, turbo smart boost controller, aeromotive FPR, fuel lab fuel filter, full 3" exhaust w/magnaflow race muffler, -8AN feed, -6AN return, FIC fuel rail, cam gears, Fluidampr harmonic damper, zaklee clear timing cover, saturn alternator relocated to back.
Mods-Engine
6 bolt stock bore, 8.5:1 comp wiseco HD pistons, Manley turbo tuff Rods w/625+ bolts, acl bearings, ARP L19 head studs, arp main studs, cometic mls head gasket, 272 cams, crower springs/retainers, 3g lifters, balance shaft removal, 1g head stock ports with some bowl smoothing done by me.
Mods-EMS & Logging
ECMlink V3 w/ speed density, defi egt, autometer ultra-lite oil press, boost, water temp, volts, monster tach, aemR1 wideband in front o2 location. Tuned by MY1gDSM
Mods-Drivetrain
quartermaster twin disk clutch, 4 bolt rear, shep stage 3 trans w/welded center diff, shep x-sfer case
Koni Yellow/GC coilovers, "big brake" conversion, drilled rotors, Ingals toe adjust rear arms, fd rx7 13lb rims with M/T et street bias ply 26x10.5 tires
Parts Wishlist
DSS driveshaft and axles
1/8 Mile E/T
7.580
1/8 Mile MPH
96.090
Timeslip Video Link
Watch Video
Timeslip Photo Link
Timeslip Details
Track Name : Quacker City Motorsports Park
Nitrous : No
Fuel Used : Pump gas
Tires : Street Radials
Sponsored Car : no
0.0 lb/ft
BadManGSX
Share this Vehicle
