Please Support Morrison Fabrications
Please Support ExtremePSI
420A Visual Guide: 420A Motor and Transmission Mounts
This guide is for the North American 1995-99 model year Mitsubishi Eclipse RS & GS COUPE (Not Spyder Convertible) and 1995-98 Eagle Talon (base) and ESi models equipped with a 420A Engine ONLY.
Note: All parts shown are New Old Stock (NOS). While I tried to source the example parts shown here from reputable sources, I cannot guarantee their authenticity.
Disclaimer: this info may not be comprehensive or exhaustive, and may contain mistakes or errors. If you see a mistake or something missing, feel free to drop a comment.
Front (Roll Stopper) Mount​
  • Auto Transmission: MB844275
  • Manual Transmission: MB844274
Center Hole Fasteners​
  • M10x75 Bolt: MF140473
  • M12 Flange Nut: MB288462
Mount Fasteners​
  • M10x30 Bolt (2 qty. required): MU242010
Left (Transmission) Mount​
  • Auto Transmission: MB910661
  • Manual Transmission: MB910660
Stoppers​
  • Auto Transmission (2 qty. required): MR333457
  • Manual Transmission (2 qty. required): MB911549
  • M12x95 Bolt: MS100923
  • M12 Flange Nut: MF434106
Mount Fasteners​
  • M12 Self Locking Nut (3 qty. required): MB242260
Right Mount​
Right Mount: MB910657​
Stoppers (2 qty. required): MB911547​
  • M12x108 Bolt: MB844519
  • 12mm Spring Washer: MS450044
Mount Fasteners​
  • M12x74 Bolt: MB911545
  • 12mm Self Locking Nut (2 qty. required): MB242260
Rear (Roll Stopper) Mount​
  • Auto Transmission: MB910663
  • Manual Transmission: MB910662
  • M10x90 Bolt: MB007173
  • 10mm Spring Washer: MS450043
  • M10 Nut: MF430122
Mount Fasteners​
  • M10x25 Bolt (3 qty. required): MB007176
Just a bit of additional info for those interested: The front roll stop mount center hole will fit a 16mm or 5/8" bolt. Since the bolt used is so small, there can be extra engine movement under 'spirited' driving. By taking out the bracket and matching the hole size with the mounts' and using a bigger bolt, there is minimized slop.
