92_6bolt_1290
- 124
- 1
- Feb 2, 2010
Jenison,
Michigan
Ok, i've been through a ton of "no start" threads and still haven't quite figured out whats going on with my 92 GSX. On random occasions it will decide it doesn't want to start. The fuel pump will kick on, starter will crank, and the check engine light will come on for its usual 5 seconds but my injectors will not pulse. The ignition side of things seems to be good because I get spark and I have a good tach signal. I have been through half of the wires going to/from the ecu checking for voltage and I seem to be getting battery voltage where it needs to be. I have checked the injectors with a noid light so i know they aren't pulsing but when the car does run my noid light doesn't light up as well as it did before the problem started occurring. I also checked the resistor box and get 6.2 ohms for each injector which "seems" good but i'm not gonna rule out the resistor box. Is it possible that I could have an issue with the hacked 2g maf maybe or even a false reading from the coolant temp sensor because when it does cold start it runs very lean and until its warm it will randomly act like it wants to stall from lack of fuel. But once its warm everything will be fine, and if i shut it off it will start right back up. Also, like I said, the problem is totally random, sometimes it will cold start. I will be venturing to the local u-wrench-it today to pick up a non-hacked 2g style maf to see it my issue lies in that. And yes, I do understand open loop and closed loop, thats why I'm going after the MAF first because it and the temp sensor are the only readings the ecu looks at until the engine is warmed up. But any possible insight would be great, thanks.
