govproperty
- 153
- 0
- Jan 5, 2006
Wilmington,
North Carolina
I am having a problem getting the car to crank consistently. When it does it starts and runs fine. I moved that battery from the back of the car to the front subframe to eliminate some possibility of voltage drops causing trouble. The battery is at 12v and my charger says that it is still good. I also tried it with another battery and got the same results. I replaced the starter just to be sure and it didn't change. I am getting 6v to the start solenoid when the key is in the start position. If I remove the wire and check for voltage with the key in the start position I get 12v. I don't know if a 6v drop is normal. The solenoid sounds like it is moving however the engine won't crank all the time. Also, I removed that starter and wired it up but without the engagement of the flywheel and I could not duplicate it. I also, could not duplicate it if I used a handheld remote start switch to activate the solenoid. My train of thought was that there might not be enough amperage in the solenoid wiring to pull the solenoid all the way in or I have another bad starter. I don't feel good about driving it anywhere since I don't know if I could get it started once it is there. I am open to any suggestions.
