BLOHS7844
- 300
- 0
- Oct 25, 2011
Appleton,
Wisconsin
I just had some machining done to my head (exhaust stud) and replaced my head gasket, did the timing, and all of that. It was my first time doing any of that though.
I went to start it up and it was making some of the worst noises imaginable. Grinding like gears grinding. It was in neutral so not the trans. But could it be the starter? I didn't even touch that.
It made a terrible crashing noise after a couple seconds and my first thought was a bent valve. The timing belt is still tight. When I did the timing I made sure the dowel pins were facing up, cams aligned, and the crank in the right spot. (no balance shafts) The noise was kinda like something breaking. Somewhat in a way like glass breaking? The problem got worse each time I tryed cranking it. I'm really afraid to try again
I took the spark plugs out and valve cover off for a quick visual inspection and didn't see anything out of the ordinary. cylinder 2 had some smoke coming out initally when I took the spark plugs out. I noticed it like 2 minutes later too. It smelled more like gas than the other cylinders. All the spark plugs smelled like gas like I would expect.
I'm 90% sure I got the spark plug wires in all the right places. What do you think?
