MNGSX
- 2,538
- 25
- Mar 30, 2003
Bloomington,
Minnesota
Eagle has (last june) released some titanium connecting rods for Hondas and SBC's that are quite affordable and they say they have new applications in the works. The honda rods list at $1200 but I have seen them for a bit over $1000... At $1200 that is 300 per rod. That is $200 less than what the lowest price once was. I think we all need to start riding eagle products ass to make ti 4g63 rods available. Yes I know there are GRP and groden aluminum rods but ever see all those nick nacks made out of used pro racing aluminum rods? So spend $1200 instead of $600 and not have to do it again unless you really blow the thing.
A 4g63 ti rod would weight about 375gr as opposed to about 576gr for the std eagle rod. A guessbased on the difference between the two honda rods but close.
That is a pretty big weight savings. All engines are different based on rod length and journal size but around 25% of a rods weight is reciprocating weight. So you go from 144gr of reciprocating rod weight to 93.75gr. You go from 432gr of rotating mass to 281gr.
Multiplied by 4 that is 200gr of weight that does'nt have to go up and down per rotation and 604gr that does'nt have to spin.
So 7.05 oz or .44 lbs of reciprocating weight is cut as well is 21 oz or 1.33lbs rotating weight. All the lightened cranks do help but each ounce cut from what goes up and down (reciprocating weight) is like cutting a pound from what goes around and around.
