ronnie81592
- 0
- Jul 30, 2013
Brockway,
Pennsylvania
I was driving home tonight when I suddenly lost power steering. I checked under the hood and found my alternator belt had been shredded in half (did not get caught in my timing belt thank God). I just recently replaced my belt with a POS Goodyear belt from Hovis about a month ago and it just recently began squealing on startup over the past week.
Also, I put in a water pump just before I got the new belt and a reman. alternator a couple weeks ago so I highly doubt the bearings in either one have gone bad. I put the pulley back on the water pump the correct way so it can't be that either.
I was wondering what could cause these belts to keep breaking. I have read on other forums that if one of the pulleys is misaligned, they will just chew right through the belt but I'm not sure how to really test this. I don't believe it broke from undertightening the alternator tensioner either since it was shredded and not a clean break.
Thanks in advance!
Thanks in advance!
