1G 1gb not revving or idling properly
Ki263737
May 23, 2022
Vanderhoof, BC, Canada
I'm having an issue where my car is idling and I can hear it start to sputter but then it will fix itself and then do it again like 3-5s later. It also is bogging when I try to accelerate and wont try to rev past 3k rpm.
I have looked for boost leaks didn't see any. It has a new ECU, fuel filter, and power/ignition transistor. I am currently in the process of looking at the MAF and air filter.
Are there any other things i should look at?
Proper CAS phase setting:
Could my ECU coolant temp sensor be the issue? At operating temp its down some ohms
I used my friends laser as reference his was at .24 and mine was between .19-.20 ohms
Once again its been a bit, got the car running nice again I didn't want to think that I bought 3 bad ecus but I did. replaced the capacitor on one of them and that fixed it
  • For sale 4G63 Brake booster/pedal assembly
    2G manual pedal assembly clutch,brake and gas $752G brake booster/master $35 (Will fit 1G as...
    • Dsm_canadian_mike
  • For sale 4G63 MHI EVO 3 16g Turbo
    MHI Evo 3 16g Turbo $235 + shipping and paypal fees* I priced this cheap as it is setup for an...
  • Wanted 2g Looking for a 2G GS-T rolling shell
    Looking for a rolling shell near Sc to Va
    • Ducxy
  • For sale 1990 eagle talon partout
    Parts are coming off, lmk what you want. Prices are negotiable. I can bundle the roller with...
    • El_marto
  • For sale 6 bolt short block .020 Wiseco/Crower rods
    6bolt .020 over, Wiseco pistons Crower rods
    • ky90gsx
