- Year
- 1993
- Model/Trim
- Plymouth Laser RS Turbo AWD
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- * ENGINE * ( 6 BOLT )
- Fresh uncut OEM 6 Bolt Crank
- Wiseco Pistons 20 over ; 10.5:1 compression
- R&R Aluminum Rods
- Balance Shaft Delete
- Kiggly Girdle & ARP Hardware
- L19 Head Studs
- FF OFH
- Fresh 1G Cylinder Head
- BC 280 Cam Shafts
- BC Springs & Retainers
- Kiggly HLA
- HKS Timing Belt & OEM Timing Components
- HKS Head Gasket
- Fluidampr Crank Pulley
- NEW OEM Black Top CAS
- Valve Cover w/ AN Fittings
- Custom Catch Can
- JMFab Billet Spark Plug Cover
- Coil Pack Bracket
- NGK 8 Plugs & Accel Wires
- Torque Solutions Driver Mount
- Saturn Alternator, relocated to rear, with full 0/1 AWG wiring
- "S" wire ran to potentiometer
- Aluminum Radiator w/ Dual Fans
- Precision 6262 Turbo
- FMIC w/ Powder Coated Piping
- Tial Wastegate
- Full 3” Downpipe & Exhaust
- Hallman Boost Controller
- 4” Intake
* FUEL *
- Modified Full Blown Pump Hanger
- (2) Heavily modified Walbro 450s
- 8AWG PTFE wiring direct to pump motor
- Bulkheads through housing to 2awg rewire
- AN Lines from Tank to Engine Bay (-10 feed)
- AEM FPR
- Aeromotive Fuel Filter
- FIC 2150cc Fuel Injectors
- FIC Fuel Rail
* Tuning & Electronics *
- DSM Link V3
- SD Conversion
- 4 Bar Map Sensor
- PLX Wideband
- Autometer Boost Gauge
- Autometer Pyro/EGT Gauge
- Autometer Voltage Gauge
- Autometer Shift Light
- Sony Head Unit
* DRIVETRAIN *
- Quarter Master Twin Disc Clutch
- TMZ Flywheel
- Dual Synchro Trans
- OEM Driveshaft Rebuild & Balance
- 4 Bolt LSD Rear Differential
- Torque Solutions Shifter Cable Bushings
* SUSPENSION & Brakes
- FEAL Coilovers
- SSR 16” wheels
- Firestone INDY 225/50R16 Tires
- Drilled & Slotted Rotors all the way around
- Dual Piston Front Calipers
- Front Lower Control Arms w/ Energy Suspension
* Miscellaneous *
- Powder Coated Valve Cover
- Powder Coated Intake Manifold
- Powder Coated Bumper Brackets
- Powder Coated Headlight Brackets
- Powder Coated Compressor Housing
- Powder Coated Radiator Brackets
- Optima Red Battery
- Battery Relocated To Hatch
