- Year
- 1995
- Model/Trim
- Mitsubishi Eclipse N/T
- Transmission Type
- Manual
- Mods-Bolt-on
- cold air intake, obx-r headers with heat wrap, test pipe, tsudo n1 2.75" cat-back exhaust, ngk spark plugs, EGR block-off plates, gates timing belt, oem radiator, royal purple oils, earthing kit, Bored and honed throttle body & polished butterfly, Walbro 255lph fuel pump, ported intake manifold, underdrive crank pulley, COP conversion, obx-r custom re-machined fuel rail, tomei afpr, 24# injectors, custom oil pan, custom engine mount, slim radiator fan, 10 row oil cooler with custom machined filter head and Parker quick disconnect and fittings and -10an stainless lines,
- Mods-Engine
- 2.4L edz swap, SRT-4 pistons & rods, shaved block, SRT-4 water pump & Gates timing belt, 2g stratus oil pump, balance shaft elimination and baffles installed, port matched intake & exhaust ports,
- Mods-EMS & Logging
- AutoMeter A/F ratio gauge, white/indigo dash gauges, ntk o2 sensor, new denso tps,
- Mods-Drivetrain
- short throw shifter, cv axles, Energy Suspension shifter plate bushings, Royal Purple gear oil, Exedy racing clutch, neon flywheel, shift linkage bearing mod,
- Mods-Handling
- B&G lowering springs, front/rear strut tower bars, lower tie bar, metalic brake pads, rear disc brake swap, 17" 5 spoke Mustang Saleen wheels wrapped in Hankook Ventus V4 tires, Energy Suspension Control Arm, A-Arm, & Shock Buchings front/rear,
- Parts Wishlist
- BOOOOOST!!!!
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Timeslip Details
- Fuel Used : Pump gas
Tires : Street Radials
- Dyno TQ
- 0.0 lb/ft
