1996 Mitsubishi Eclipse GSX Vehicle Profile & Build Thread
NickNorth11's Eclipse GST (AWD swap)
Turbo Type
50-trim
Build Type
  1. Street
PTE 5031re, Punishment Racing ss o2 housing, Megan Racing ss 3" dp, Megan Racing ss 3" cat-back, fmic, Tial Q bov, Taylor Thundervolt 50 wires, Dynatek Arc-2, FP intake, 9" K&N filter, Air box, ECMlink-controlled IR mbc, JMFab welded up valve-cover, JMFab deluxe catch-can, JMFab deluxe coolant reservoir, Fel-pro permatorque h.g., 3" GM maf, FP exhaust manifold, Magnus smim, 1g n/t throttle body, -8AN proclassic fuel feed, Fuelab 818 filter, Walbro 450, FIC fuel rail, -6AN proclassic fuel return, , Bluemax 1450's, Fuelab afpr, Earl's in-line oil filter, Mishimoto x-line radiator, (2) spal 12" slim fans, grounding kit
Mods-Engine
2.3L (Carrillo, Wiseco, ARP), HKS 272's, Built head (Supertech, 1mm over)
Mods-EMS & Logging
ECMLink v3, AEM boost gauge, AEM eugo wideband, AEM 3.5 bar map sensor, Greddy turbo timer
Mods-Drivetrain
Shep stage 4, SBR shift kit, MR short shifter, Quarter Master gear-drive twin disk, skateboard bearing bushings, Frontline Fabrications rear diff cover, aluminum rear diff bushings, aluminum carrier bearing bushings, aluminum subframe bushings, evo 8 enkies with Sumitomo HTR+ 235/45s
Prothane mounts, Ground Control springs with Tokico Illuminas, hardware store rear camber kit
Parts Wishlist
Bigger turbo (FP Black?)
Better tires (Dunlop Direzza ZII Star Specs?)
nicknorth11
Rating
5.00 star(s) 1 ratings
Share this Vehicle
