Please Support RTM Racing
Showcar Build 1996 Eclipse GSX
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Drivetrain
AWD
Build Type
  1. Showcar
INTERIOR
Black Dash Swap
4G Eclipse Leather Heated front seats (Re-Dyed Black)
3G Eclipse Rear Seats
New Black Carpet
New Black Floor Mats
Alcantara Headliner / Door Cards / Glove box / Center lid
Canadian Cluster (km) Swap
White LED's in All Clusters
Blox Guage cluster surround
Innovate Wideband Guage
Innovate Boost guage
Momo Pedals
Momo Shifter
Razo Mirror
Nrg Short Hub
Nrg Quick Release Hub
NARDI Deep Corn Steering Wheel
Sky-High Car audio Sound Deadening
STEREO
Eonon double din deck
Hertz Millie 6.5 inch componets Front
Hertz Millie 6.5 inch componets Rear
6x9 to 6.5 inch Speaker Adapter Rear
Sky-High Car audio 0 GA amp wiring
Sky-High Car audio 12 GA Speaker Wiring
Hertz Millie amp 4ch
Hertz Millie Amp mono
Jl w6 Subwoofer
Audiovox Alarm
Radar mirror mount / wiring for Escort 8500ix
BODY
New windshield
Flush mounted Rear Glass with no molding
2gb Bumpers / Skirts
Custom Front Lip
Smoked Crystal Marker lights
Rolled Fenders F / R
Shaved Rear Wiper / Squirter / Antenna
Shaved Hood Squirters / Squirters installed on wipers
Legacy LED Tailights
Painted center taillight
New Hatch Shocks
Front Hood Shocks
New headlights
BOOSTED Billet Door Handles
Bottom of car completely wire wheeled / Undercoated and Painted
Custom Tri-Coat Paint with 5 layers of clear
WHEELS
19x8.5
Nitto Nt-01 Tires - 235/35/19
Muteki Lug nuts
Mods-Engine
6 Bolt 2.0 Block with 2g head
BLOCK
Eagle Forged Crank
Wiesco 1400HD Pistons
Manley I Beam Rods
ARP 625 Rod Bolts
Balanced rotating Assembly
ACL Race Bearings
Kiggly Main Cap Brace
Balance shaft delete
ARP Main Studs
ARP L19 Head Studs
ARP Crank Bolt
Stainless Steel O-Ringed Block
HEAD
SLOWBOYS Racing Stage 5 Port/Polish Race Head
+1 mm Manley intake valve
+1 mm Manley exhaust valve
GSC S3 Cams
Fidanza Cam gears
ARP Cam Bolts
ARP Cam Tower Bolts
Kiggly HP Springs / Titanium Retainers
Kiggly HLA
3G Lifters
HKS Rep Clear Cam gear cover
INTAKE
JMF Race Intake Manifold
RTM Thermal Intake Mani Gasket
S90 74mm throttle body
3 inch Intercooler piping
Vangen Clamps
Mishimoto 4 inch Intercooler
HKS SSQV 4 Bov
IGNITION
R35 Skyline Ignition Coils
R35 COP Billet Mounting Plate
6 bolt in 2g Kiggly crank sensor
BR8ES NGK Plugs
FUEL
Magnus Fuel Rail
Aeromotive Fpr
Bosch 2150cc injectors
10 guage Fuel Pump Re-wire
Dual Walbro 450LPH Pumps
8AN PTFE Feed Line
6AN PTFE Return Line
30 micron filter
TURBO
G42-1200 Turbo
JMF T4 Twin scroll manifold
Twin 40mm Hks Wastegates
RTM Head Feed Turbo Line / Drain Line
4 inch Intake
4 inch Downpipe
4 inch exhaust
COOLING
VW Tucked Radiator
20an Rad hoses
Samco hose kit for heater core
Mishimoto 26 row oil cooler
Forward Facing Oil Filter Housing
Oil fiter relocation with 10an lines
MISC
New Bosch starter
New Bosch Front 02 Sensor
New Front / Rear Motor Mounts
Prothane motor mount Inserts
Dual 10an Vents in Valve Cover
Honda Vented Battery Catch Can
Volvo electric power steering swap with 6an Lines
Mods-EMS & Logging
ECU
Dsm Link V3 with Speed Density
AEM 5 Bar Map Sensor
AEM IAT Sensor
AcDelco Flex Fuel Sensor
Mac 4 port boost controller
Innovate Boost gauge
Snow Performance Methanol Injection
Also have Tuner Nerd Knock Monitor Pro for tuning
Mods-Drivetrain
BRAKES
Cts-V Brembo Calipers - Front
Cobra 13 inch rotors - Front
Evo X Brembo Calipers / with working parking brake- Rear
Evo X Rotors - Rear
Techna Fit SS brake lines
3G 1 1/16th Brake Master
3G Brake Booster
Ate Racing Brake Fluid
TRANSMISSION
Jacks Stage 2 Transmission Rebuild
Boostin Billet Transmission Bearing Plate
WSS Billet 1/2 Shift Fork
Quarter Master Twin plate Clutch
ARP Flywheel Bolts
Competition Clutch Forged Clutch Fork
ACT Throw Out Bearing
New Clutch Master
New Clutch Slave
Braided Clutch line
RTM Extended Clutch Rod
B&M Short Shifter
New Shifter Bearings
New Shifter Cup
RTM Racing Shifter Solid Base Bushings
Ball Bearing shifter Cable Mod
DRIVETRAIN
Quafe Front Lsd
Tmz Speedo Gear
Jacks 4 spyder Center Differential
Rebuilt Rear Lsd Differential
Magnetic drain plugs in all
RTM Solid driveshaft bushings
New Front wheel hubs
New Rear wheel hubs
Extended Wheel studs
BRACING
DC Sports Front Strut Bar
DC Sports Rear Strut Bar
BOOSTED FAB Chromoly Fender Braces
Volk Solid Front subframe bushings
Volk Solid Rear subframe bushings
DCP Differential bushings
DCP Rear Differential Billet Mounts (Both)
SHOCKS
Koni yellow Shocks
Coilovers
700 lb Hypercoil Springs Front
450 lb Hypercoil Springs Rear
Billet Top hats
Spherical Top Plates
New Shock bushings
New Rack and pinion
FIBA Outter tie Rods
New Tie rods inner
New Front Forward lower control arm
New Front Rearward lower control arm
New Front upper control arm
New Rear upper control arms
Volk Rear Lower Control Arm
Volk Rear Adjustable Trailing Arms
Volk Rear Toe Adjustable Arms
Prothane Polly Bushings - Rear
Rm Racing Front / Rear Sway Bars
New Front swaybar endlinks
New Rear swaybar endlinks
Parts Wishlist
BF Crossmember
Par gearset 1-5
Frontline T-Case Brace
Frontline Rear Differential Cover
MFactory Evo Rear Differential
I Have the Acura jewel headlight projectors as well, just have to retrofit them into the eclipse housings.
Background
The 2g Eclipse was always a car that caught my attention as a kid, I seen this car come up for sale (May 2021) in rough shape but it had potential, lightly modded, no rust but paint was jacked up. Thats what started this spiral of time and money, Im ocd picky and hate cutting corners so I wanted to build a super clean all-round car that could handle the hyw cruising and some drag... So its not being purpose built for anything, meaning it never will be great at one thing but it will be good all round.
I decided to do a ground up build (striped to bare shell and rebuilt) Im currently still in the finishing stages and have 1600hrs into it so far. Turbo set up curently is a t04e at 30 psi that was seeing 56 Lb/Min on Dsmlink, and I have a Precision 6766 to go on when I want to crank it up to 950+
schafer240
More in 2G DSM
Share this Vehicle
