Please Support Kiggly Racing
Road Race Build Solomon's 2GNT Build ('98 RS)
Ownership Status
Currently Own
Mitsubishi Eclipse N/T
Drivetrain
FWD
Build Type
  1. Street
  2. Drag Race
  3. Autocross
- Yonaka 2.5" cat-back system.
- Megan Racing test pipe.
- 3 gauge cluster.
- Walbro 255lph fuel pump.
- ProTune high flow fuel filter.
- Hydraulic hood support shocks (prop-rod delete).
- Rear 02 delete and capped off.
Mods-Engine
- .020" over.
- JE 10.5:1 forged pistons (12.5:1 compression).
- 64462 Crower Stage 2 camshafts.
- SBI +1mm valves.
- Brian Crower titanium springs & retainers (BC2160).
- Eagle H-beam rods and ARP bolts.
- Fidanza adjustable cam gears.
- PermaTorque MLS headgasket.
- ARP headstuds.
- Gates blue racing RPM timing belt.
- Shaved head & gasket match port work.
- MPX underdrive pulley.
- Samco silicone radiator hoses.
- PT lifters.
- PT rocker arms.
- 2.4L valve cover & custom breather assembly.
- EGR delete and block off plates.
- EVAP deleted completely.
- Cruise control delete.
- A/C & tensioner delete.
- Modified 60mm throttle body.
- Stock intake manifold, 60mm plenum port matched to throttle body, IAC port closed with 3/8" pipe plug, lower runners gasket matched.
- 4-1 exhaust header and down-pipe (heat wrapped).
- ProSeal piston rings (1.2, 1.2, 3.0).
- Taylor Cable Thunder Volt plug wires.
- NGK V-Power @ .048"
- Replacement radiator.
- Clevite main & rod bearings.
- Stock hose clamps replaced with screw clamps.
Mods-EMS & Logging
- MS3 standalone.
- Glowshift wideband 02 module and 52mm digital gauge, in conjunction with MS socket to eliminate OE sensor.
Mods-Drivetrain
- Quaife LSD.
- New Mopar shift cables.
- Megan Racing short shifter.
- Drilled casing oil passages.
- Energy Suspension polyurethane shifter bushings on interior.
- Torque Solution shifter bushings in the bay.
- TPD brass alloy synchronizers 100%.
- SouthEast Stage 1 clutch kit.
- Polyurethane engine and transmission mounts.
- GSP axles.
- 2gnt lower engine mount bolt upgrade.
- Eibach Ground Control coil overs.
- Koni Yellow struts.
- Powerstop drilled and slotted rotors.
- Brembo brake pads.
- Energy Suspension polyurethane sway bar bushings.
- Archer Fabrications aluminum spare tire well delete panel.
Parts Wishlist
GSX dual piston calipers & rotors. 12.5:1 comp pistons. Nothing more.
Background
Purchased: 1/4/2018
Constantly turning wrenches to achieve my goals.
Dyno Type
Mustang Dyno
Dyno Shop Name
Henson Performance, Alabama
Dyno Session Details
93 pump gas
Videos
BLACK'98DSM
Comments
15
More in 2G DSM
More from BLACK'98DSM
Share this Vehicle
