Mischif
- 563
- 8
- Mar 31, 2008
El Paso,
Texas
Okay so i was throwing a code for injectors every now and then. Tried 3 different resistors, and none made a difference. So i went and bought some injectors and put them in. Still getting the injector code every now and then, just not as often. So after that i decided to wire in new injector pig tails, since mine were hard and brittle. I hit up the junkyard for some better pigtails. The ones i got were in great shape, still nice and soft and flexible, and the harness clips felt solid. I cut the pig tails off from about 2 inchs from where the main wiring harness bolts to the back of the intake manifold. And thats were i stripped my harness down to replace the ones that were on there. My wideband is acting a bit more normal now. And i have only thrown an injector code once, but i may have forgotten to erase the old one. So i started logging, and noticed my o2 volts were all over the place. Checked out my connections for the sensor and the engine harness side connector was in bad shape, so went back to the junk yard and got one in way better condition. Spliced the new o2 pigtail in the same place where i did the injectors. So i log again, and now my o2 isnt doing jack. I had another one that was just missing the pig tail, so i wired one onto it and replaced the one on the car with it. I log, and now its working perfectly. I let it idle for a good 10 minutes and the o2 volts were fine the entire time. later on tho i logged it again and the volts were going crazy again. I noticed the electrical tape on the o2 wire was super soggy since where i spliced the pigtail on is right above the mani. So i figured that let the wiring cross some, so i re wired the pigtail to the sensor, but its still acting strange. I'm hoping the sensor just died. I hope i dont have to go and redo the entire o2 wiring from the ecu to the sensor. Thats one problem im having.
The other thing i noticed today while messing around with it, is that one of my injectors feels funny when it "pulses" If i touch injectors 124, i can feel them "pulse", its pretty noticeable. But when i touch injector 3, i can barely feel the "pulse", its pulsing at the same rate as all the others, the intensity just is way less. If i put the injector connector for 3 on any of the other injectors they pulse normally. If i put any of the other connectors on injector 3 it still barely pulses. So i decided to test the connectors, and all 4 of them gave me the same readings. So i don't think its the wiring. Does that sound like the injector may be bad? Im not sure if the rubber seat im using for that injector could just be muffling the pulse feeling i guess? I have 3 different seats on my injectors. 2 of them have the seats that are specifically made for fic's. 1 has one i got from home depot, and the last one has one from harbor freight(i ripped one of the fic's so i decided to try the 2 different kind i was able to find that fit decent). None of them leak boost. I know one of those 2 non-fic seats was kinda thick, and im not sure if thats the one on injector 3. Id pull the rail and check but one of my 3 bolts to my fuel rail snapped so i had to tap it, and i've already had to retap it once, because every time i take it out it strips. So i dont really want to have to pull the rail and test and see if it could be the injector seat im using.
Sorry for the story book. Any ideas? Things i could try to rule out wiring issues?
