boostmaster123
- 92
- 0
- Nov 16, 2002
Chicago,
Illinois
i just installed autometer mechanical boost and Egt gauges and electronic oil pressure gauges. my problem is that after i installed the three gauges the only thing that works is the lighting. when im driving the egt doesnt move from 500degrees F and the oil pressure gauge only moves a little bit when i get on it. do i need to ground the gauges to the engine? i grounded them to a piece of steering metal under the dash and i tapped them into the 12v head light wire. also i did not install the boost gauge yet and it reads vaccum pressure, do i want to "T" into the hose going from the intake to the FPS or somewhere else?
any help would be much appreciated.
thank you
Mike
thank you
Mike
