1991TsiTurbo
- 0
- Jan 8, 2003
Does anyone know where I can go to find a ring and pinion gear set for a 4-bolt rear? Satan wants $565 for the set. I kinda exploded my rear end
Also, does anyone know why this happened? Should I check anything else on the car to make sure it won't happen again. The car is a 93 Laser RS AWD turbo automatic if it helps. Thanks in advance.
Also, does anyone know why this happened? Should I check anything else on the car to make sure it won't happen again. The car is a 93 Laser RS AWD turbo automatic if it helps. Thanks in advance.Attachments
