EVO III Boost Creep Problem Solved!
Boiler2
149
Mar 9, 2003
Lancaster, Pennsylvania
I am posting this thread for all those people having boost creep problems on the EVOIII 16G turbo.
My mod list is up to date and if you notice I have a ported 2G O2 housing and full 3” turboback exhaust. I bought my EVO3 from SBR back in Sept of 2003. It has the 34mm flapper mod.
I installed it in early Oct of 2003. In the process, I ported my 2G exhaust housing exit to match the already ported 7cm turbo housing done by SBR. It is true about what you read about the 2G O2 housings not exactly matching the SBR EVO3 turbo housing exit. The bolt holes match up though, which is all you need because you can port match the rest.
After the initial install, I could not run less than 22ps,i which is not too good on pump gas for me because I saw a bad timing curve. Sometimes it would creep to 24 psi. I disconnected the boost controller and it would pause at 11psi(stock wastegate pressure) then rocket to 22 and hold there. And I knew colder weather was coming which could cause more problems (I am in the South, but from the North).
Thinking about how to control boost creep – it is all about the air following the path of least resistance, which in my case was through the turbine wheel and out which caused me boost creep and more boost than I wanted.
I then dropped the turbo and ported the hell out of a few things. First, I drastically cut back the divider in the O2 housing to make the exit wastegate path larger. I had already ported the exit of the O2 housing so that was left alone. Second, I ported the O2 housing inlet side to match the turbo exhaust housing. Third, I ported the step at the bottom of the turbine housing wastegate area. This is where the air coming out of the wastegate hole practically hits a perpendicular wall and then has to flow out. I simply removed this so the air exiting the wastegate hole hit more of a curves wall then out to the O2 housing. Then I put everything back together and started it up.
After a few settings, I still had boost creep but it was only ever to 20psi, which is a little better on pump gas but not where I wanted to be. Then it got colder (November) and I started having serious creep back to 24psi. So it was time for plan B.
I dropped the turbo again and this time ported the wastegate hole on the turbo slightly making sure I would still get a good seal with the flapper. The other thing I did was from a vfaq I saw. I ported a step in the 7cm housing area so the air would flow towards the wastegate hole better when it opened. If you looked down into the 7cm housing, I ported it so you could see the flapper door easily. I removed a good bit of material. That was it – so I again put everything back together.
I turned the boost down and to my surprise, it held at 14psi which is where I set it. I could go lower to the stock spring setting but that was good enough for me. I now run a happy 18psi on pump gas and it holds perfectly with no more timing retard from high boost levels. I have run a 7.81 at our local 1/8th mile track @ 83mph. (our track is 60 feet shorter than a true 1/8th mile … don’t ask). This should be good for mid to upper 12’s on a true ¼ mile.
Sorry I do not have any pictures, but you can email questions and I can try to answer. Thanks.
Sup local, I'm right over the bay from you in Mobile. Glad to hear you got your boost creep corrected. I WISH I had a problem with creep but since my dp is stock :( I dont. BTW what track are you referring to? Irvington?
Yes ... that would be Irvington. I have been going over there about every 2 months. I plan on going to the true 1/4 mile in Gulfport soon.
What do you exactly mean by this? Could you point me in the right direction of this vfaq. I am having the same problem with my stock 14b (11psi creep) and have to pull the turbo again to do some more porting.
Check out this link... http://vfaq.com/index-main.html --> click the "Porting" link and go to "turbo's". BTW what size of downpipe do you have?
I have seen that link and it doesn't mention anything about porting in a step to improve flow towards the wastegate. I have ported my turbo, mani, and O2 sensor housing already, but am still experiencing creep, massive creep. With direct a boost/vaccum source to my wastegate actuator, boost holds at about 11psi for a second and then starts to creep a bit in 1st and 2nd (upto about 15-17psi), and jumps to about 21+psi in 3rd and 4th.
I have replaced/checked all vaccum hoses for leaks and did an intake leak test on the whole intake tract with no leaks what so ever. I am pinning this down on the turbo, since I have tried everything, and am pulling it to port it again (mainly more work on the wastegate, possibly flapper upgrade) and would like to try this "step" idea.
(running a 2.5"dp to 3" catless back exhuast to a straight thru design muffler, mods in profile)
Sorry the link didnt help you. I am pretty sure that he's talking about porting out the wastegate on the turbo housing to make the flapper open wider than unported near the side of the wastegate opening where the exhaust usually hits the O2 housing dead on. I'll see if I can locate a pic for you.
Thanks for the help Ricekiller ... we should meet up at the track sometime. I will try to contact you before I go. I have a black GSX.
As far as what I meant about the step ... I will try and explain via words since I have no pictures and am still looking for the vfaq. If you are looking down from the top into the turbine housing, the exhaust gasses have a choice to go through the turbine wheel or through the wastegate hole. The way my EVOIII came from SBR, it was ported really nice to maximize flow into the turbine wheel. This is normally great except that with my setup, I could not flow enough into the wastegate hole to limit boost. I simply took a electric die grinder and ground a good amount of material right above the wastegate hole in the turbine housing to essentially create more of a disturbance in the air flow into the turbine wheel and make the path of least resistance through the wastegate hole when my 34mm flapper opened. When you look from above, it looks more like a 'step' than when it originally came. That is the 'step' I am talking about.
I hope this helps. I know it is a pain to deal with boost creep. If this did not work for me, I would have been really pissed because I had already dropped the turbo a number of times. Now the car pulls hard and I am happy with my times.
I will continue to try and find the vfaq. It was not the ones on the vfaq site as far as I remember.
Boiler I'm assuming that this is what you grinded down to eliminate the creep. ^^^ Just trying to lend a hand there. BTW I've yet run that track out in Irvington but I wouldnt mind driving over there to see what kind of times I could put down. Holla!
Thanks alot guys I really appreciate all your help.
Ricekiller the pics aren't exactly what Boiler is talking about, but I understand now what he means by a "step" (although a pic and vfaq would still be nice:thumb: ))
I am droping the turbo in the next few weeks to do some more porting and will give this step idea a try. Progress reports will come in May when the weather warms up.:)
Just a thought, would funneling to much of the exhuast gases towards the flapper (especially a larger one) cause the flapper to open prematurely (too much pressure) resulting in a loss of boost? I think I will hold off on the larger flapper until after I try this.
REDBLUR ... I have heard of people having issues with their larger flapper opening too early, although I do not know how they prove this as it could be a host of other issues causing inconsistent boost.
My boost is very consistent when I get on it, and I have the ball and spring style controller. The SBR EVOIII comes with a stronger wastegate spring (11psi I think) and I have no complaints.
I was very scared to do this 'step' mod because of that issue and possibly hurting overall flow, but I decided this was the last time I was going to drop the turbo and I was going to do everything possible to eliminate my creep. It turned out pretty good.
You are the second person I have heard of doing this port job and having it eliminate creep. Good job!
I'm going to order a evoIII turbo soon to install this spring or summer. Now before I port it, how do you get the exhaust housing off the turbo so I don't get all the shavings into the turbine? Might be kinda basic but I don't have anything to look at yet and just wondering. Thanks.
I just got done doing the same thing.... my turbo is still apart so I will post up some pics tonight.....
I did not remove the exhaust housing before I ported. I simply put some lint free rags in the hole going into the turbine wheel and ported away. After I was done, I used a vacuum cleaner and sucked out any shavings. This worked for me.:D
is the picture on the left how it should look ported? I just recieved my Evo Mani, Turbo, and O2 and throwin it on my car that has 142k and dont want to creep till i get intense detonation. stock injectors with no S-AFC for about another month or two. stock DP with 2.5" catless exhaust,
should I be alright for creep? oh i did NOT get the 34mm upgrade, will that be a problem or should i take it to a shop ot have that installed?
First off that link isnt exactly what boiler was referring to. For the full story follow this link http://www.vfaq.com/index-main.html Click on "Porting" then "O2 housing porting". It's up to you whether to do that flapper mod. I havent done it and I have NO boost creep problems. But I DO have the stock downpipe so maybe thats a big factor for me right now. I plan to upgrade soon to a 3" dp and I dont know if that will make my car creep or not right now. But pm boiler, Im sure he has more info on the specifics.
Hey ... I did what you have listed which helped only slightly but did not fully eliminate my boost creep. I have all but given up on finding pictures. I do not remember where I saw them, you might want to try your search online. Anyway, just create turbulence before the turbine wheel so when the wastegate opens, more of the air will flow through the wastegate hole thereby eliminating boost creep. Take your time porting out the material and check and doublecheck the metal thickness so you do not port too much which could lead to cracking. Right above the wastegate hole the metal is pretty thick and can stand to be ported.
no creep!!! :D holds a steady 10psi, but my car is slow, has a bit of hesitation. need to rewire the pump and get some 660's and an S-AFC. my 3" turboback isn't on my car right now, but it is stock DP with no cat and 2.5 cat back with magnaflow muffler. will the 3" turboback with a highflow cat make it creep ya think? stoked to have my car back on the road. 2 days after i got the car it took a dump and been off the road for about a month and a half. not a good way to start off the ownership of my 1st DSM but whatever, it's all gravy now. :thumb:
RedBlur, that is a good picture. Thanks for the help. This is pretty much what I did (among the other lesser stuff).
Vee-Dubber, Glad to hear you are back on the road. If you did enough porting in the right areas, a 3" DP with high flow cat should not creep. I assume your O2 housing is ported as well.:thumb:
i have an evo 16g not yet installed and from seeing all this i wanna do this mod before putting anythign on but im still confused on what part of turbine u guys r talkin bout.. one is talkin bout looking into the 7cm part and the other is talkin bout the other side wheer the o2 housing meets the turbo.. can someone please explain what part and post some pics before i really need halp hea guys thanks fella's
