Engine Oil
Blam
186
May 26, 2003
Edmonton,
what kind of oil does everyone use?
I use Mobil 1 10w-30...but was thinking of using 15w-50...is that a good idea?
that depends on the ambient temperature. according to the owner's manual if the temp is above 32F you should use 20W-40, which would be closer to 15W-50.
I first used Mobil 1 10-30 when I got the car on my first oil change. Then my second I switched to 2.5 quarts 10-30 2quarts 20-50...now I think I will go all 20-50 cause its thicker and hopefully will create a little more oil pressure and maybe protect my thrust bearings better
i use Valvoline Super HPO 40. havent used anything else. my father used it when he had his drag car, we also use it in my moms Oldsmobile with a 3.4 DOHC. its the only oil that engine doesnt eat.
I always used Mobil One Full Synth 10W30, 15W50 will work too...
