Dragon TalonTsi
- 691
- 4
- Dec 5, 2005
Hobart,
Indiana
A friend and I are doing some research for these pumps. I had the 190 and 550's before, and no problems... Now I have a different setup in my mods list. My buddy had 650's, and a 255, but now we both are thinking about going to the 255 HP, and I did the search, and pulled up like 15 different searches, but none compared the whole Walbro lineup for DSM's. It was only one or the Denso Supra TT pump. I have read in one search, "THE VOLUME DROPS OFF LESS AT HIGHER PRESSURE. WHEN YOU BUILD BOOST THE AFPR MAKES THE FUEL PRESSURE GO UP AND THE VOLUME THE PUMP FLOWS GOES DOWN. THIS IS BAD. GET THE HIGH PRESSURE ONE. DUH." And here is another one, "If the 16g is as big as you plan on going you might as well just get the 190 pump then you won't have to get an Adjustable Fuel Pressure Regulator." See what I mean? No technical advice, no research or links to back it up, nor any maps or logs for it... I am trying to get all the hearsay and jargon crap out of these pumps. Here is another one, "190 will still overrun the stock fpr, just not as bad as the 255 and mostly doesn't cause problems that can be detected without installing a fuel gauge....mostly. I have so far helped two users with 10+psi overrun with the 190 pump that was giving them serious drivability issues, an afpr is still a good idea even with the 190." Here is someone questioning the truth on this, "Interesting. And since no one bothers to install a fuel pressure gauge when they put in a 190, no one finds out about it if there's a problem.
You're the first person I've ever seen mention anything like that, oldman." I need hardcore facts, cause I am trying to decide what upgrade to go with. Plus, this is for all the other newbies too.... Any help would be appreciated... thanks...
