what is this guys???
jeffreyinigo
65
Oct 6, 2004
Tucson, Arizona
hey guys, where does this loose connection go?? and what is it??
i found it today on the back of the intake manifold and was wondering if it would affect how my car runs. cause my car does have a hard time starting and kind of runs crappy all the time and also runs worse when the gas is almost out....
and also what kind of turbo is this? i think its a 13b but am not sure, im sure some of you guys know what it is
not sure about the connector, as for the turbo though, if its a stock turbo on a manual tranny its 14b, if its automatic, its 13G
there are a few unused connectors, such as the one you ground to set the base idle and timing and junk.
just look at everything, and findout what isnt plugged in.
There are 2 similar connectors behind the intake like what you have pictured. One goes to the knock sensor and the other is taped to the harness and unused. Check the knock sensor and if it is hooked up, that is the unused plug in the pic. I will try to get a pic in a few minutes.
I just snapped a couple of pics. If the plug is black and has green wire or wires going into it, it is an unused plug. If the plug is gray and has a black and white wire going to it, it is for the knock sensor.
In the second pic, the knock sensor connector is the gray connector on the right.
Excuse all the oil on everything, I had a small dipstick issue.
