red eclipse gsx
- 109
- 3
- Jan 18, 2004
Chalfont,
Pennsylvania
Hey all,
I am trying to remove my downpipe to install a wideband o2 sensor. My problem is one of the two bolts at the end of the downpipe, which connects to the cat, will not come off. Its the one kinda hard to get to. I have tried wd40, liquid wrench, pb blaster, I have tried kicking the wrench from the other side. I have also tried a torque wrench, but it just slips off. I got it loosened up somewhat but it just tightens up again. Now I am in a rut because the bolt is kinda stripped, so I tried using the bolt-out tool, and the wrench won't fit over the bolt-out. Also, I can only safely jack up my car on jackstands about a foot and a half because my driveway is messed up. Please, I need much help so I can get my car inspected ASAP. Thanks.
) then take it to a mechanic shop of some kind and ask (or show) them to remove that bolt for you. you can also ask them to lube up the bolt with Anti-Sieze. if you are sucessful yourself with getting the bolt off, use Anti-Sieze yourself.
