madman
- 472
- 3
- Oct 9, 2003
Kansas City,
Missouri
I've had some ongoing issues with tuning my car and my 50trim / intercooler. One issue was a not getting more than 19psi. So I've finally did a boost leak and found 2 coupler leaks in the piping.
So now confident that my boost leak was gone I went out and did a 3rd gear pull. When the boost started to come in the motor started to rev high without the car accelerating and then I got a code P0300.
Plugs are wires are within a couple months old. I've replaced 1 out of 2 of the coil packs. Fresh valve job.
Here is the log to go with it.
sec/coolant/rpm/air/timing/o2
1.12 179 2412 03.99 21 .06
1.68 179 2628 03.99 27 .04
2.49 176 2704 04.57 26 .04
3.06 176 2928 05.83 22 .10
4.15 176 3108 07.33 17 .22
4.71 176 3596 12.30 07 .94
5.27 176 4092 16.15 07 .96
5.83 176 5428 19.65 13 .96
6.91 179 6192 20.72 14 .96
7.47 179 5832 19.48 10 .96
on the dyno @.98 my A/F was 11.2 so I don't think I was too lean
If my clutch was slipping could it cause a misfire or am I having multiple issues?
