br20g question
I really dont know to many specs on the turbo but i do know that tim switzer from buschur busted like a 10.XX with a full interior and no nitrous if im thinking right. I have a picture for you with the FP green next to the buschur 20g, i got this a while ago off the dsmtalk forums. I know nothing of what i said is major info but ill try to get back to you with some info, what specificaly are you looking for though?
the size of the turbine housing, cfm, spool up time (general)
basically if this thing is badass or not
My first setup was with a BR20G. I made 367whp and 358lb/ft of torque at 21 psi (100 octane pump gas). It's a great street/strip turbo. Full boost by about 3600 even with the big clip. Its a great turbo. Plenty to dispatch most anything you'll run into on the street.
The turbo is a TD06 compressor housing, 20G compressor, TD05H turbine wheel with 25 degree clip (mine was) ported 7cm turbine housing.
jeff
