i think i have a bad coil?
patsdsm
51
Oct 10, 2004
rochester, Minnesota
my car around 3000 rpms starts to stutter, and has no power what so ever, its runs like a car with a stutter box around 3000 and wont power out of it at all
I think he was inadvertantly asking if it's his coil.
First you need to change plugs, and plug wires to see if that solves your problem. You can also test your coil for voltage to see if it is putting out the right amount.
You're on the right track though, usually studdering is cause by misfire, which is cause by some faulty ignition source.
If you wanted to test the coil unplug the coil pack connector and just take your ohm meter and measure resistance from where cyl 2 and cyl 3 ignition cables plug into the coil pack and then between 1 and 4. 2 and 3 are the two closest to the front of the car and 2 and 4 are closest to the firewall. This is secondary resistance and should be between 11.3 and 15.3 kohms.
To measure primary resistance of the coil you are going to measure where the plug connects to the coil pack. You measure between pins 1 and 3 and between 2 and 3. Pin 3 should be the one by itself at the opposite end of the locking tab. .7-.86 ohms is standard.
If your coil pack is bad, you will have misfire on two cylinders, so if it is only missing on one cylinder you should replace plugs and wires first.
i replaced plugs and wires and i still get codes P0300 Random/Multiple Cylinder Misfire Detected and P0304 Cylinder #4 Misfire so do u think i should replace my coil pack?
Are you actually having misfiring or is it just setting faults? If it is running bad, see if somebody on here lives near you and has a good coil pack to swap. They aren't that cheap. You could have coil pack transistor problem, bad ECM or even a mechanical problem. Have you checked compression?
no i cant hear it misfiring honestly it just brings these codes up all the time so maybe my timing is off a bit?
I was wondering how sensitive the primary ignition coil resistance is, I am measuring 1.3 and 1.2 ohms where it should be .7 - .8, my secondary coil is sitting nicely at 13.5 kohms. Should i replace my coil?
I had a coil that measured within all specs, but still ran like crap. I put a different, used, coil on, which did NOT measure in spec., and the car ran much better! Needless to say, I bought a new one.
That could be an O2 sensor issue. Try a different one if you have access to one.
Just did this test and secondary is within spec. Primary resistance was about 2.5-3.0 for both pairs. I'm considering replacing it or finding a refurb.
I also noticed that the metal contact inside coil #3 has this kind of dirty buildup on it. All the other coils looks fine and I can see the contact easily.
That sounds really bad and WAY out of spec. If you want a sure fire test to visually see how weak the spark is do this: http://www.dsmtuners.com/threads/is-this-a-ground-no-spark-issues.415723/#post-152745735. This link is for a 2g. For a 1g coil, use the yellow-black for plugs 2 & 3 and yellow-green for plugs 1 & 4.
Would I be able to replace just the wiring back to the coilpack connector in order to fix this or would this mean I should start looking to replace the coilpack altogether (assuming the reading is correct)?
Sounds like you need a new coil pack.
Reached out to a local mitsubishi salvage yard and they have them used for $45. I'll make sure to bring my voltmeter when I go though.
Also did a test on my PTU. Without a battery hooked up pins #3 + 8 had no continuity but #1 + 3 did. I have no alligator leads right now to try it out with the battery per the Haynes manual, but I'll get one soon before I go out any buy another PTU.
