Everything you want to know about the MAF Translator. [MAFT]
GSX4LIFE
709
30
Aug 17, 2002
Many of you have been asking alot of questions concerning the MAF-T which is why this FAQ has been added.
The MAF-T is a piggi-back fuel controller which replaces your stock MAF sensor by changing a Hotwire signal to the stock Karmen signal which is used by DSMs. It allows the use of a GM MAF sensor. Either the 3" or 3.5" sensors can be used. These sensors can be sourced either new or used. The 3" sensor is used by dozens of GM vehicles including 96+ Blazers/Jimmys, S-10 pickups, Any vehicle with an LT-1 engine (Camaro/Firebird), and Impala SS. The 3.5" sensors can be found on vehicles using the potent LS-1 engine, including Camaros, Firbirds, Corvettes. Aftermarket MAF sensors, such as those sold by Granettelli Motorsports are not compatable with the MAF-T.
The MAF-T's installation is very straightforward with only one wire to splice. There are 2 harnesses from the unit which simply plug into your stock MAF harness connector and the GM MAF itself. The GM MAF can be configured in 2 ways.
Blow Through , the most popular, is when the MAF itself is in the upper IC pipe. This is beneficial for 2 reasons. First, it eliminates a restriction before the turbo; and second, you can VENT YOUR BOV , which everyone loves ;), by putting the sensor after the BOV and allowing backed up charge air to be vented before it is measured. *on a side note, NO, you cannot configure your stock MAF sensor to be used as a Blow Through sensor. The operation of a Karman Vortex MAF sensor cannot operate in this manner, and the sensor itself is not built to withstand any positive pressure.* Blow Through sensor placement has been discussed and still, no definitive answers has been reached. As a rule of thumb, the sensor should be somewhere on the straight portion of your UICP, at least several inches before the bend into the throttle body. Mine is about 8" from the bend.
Draw Through, which is far less popular, but still affords less of a restriction for the turbo, over the stock MAF. In this installation the GM sensor is simply installed in the stock MAF location. You cannot vent your BOV this way, since the sensor will be before the BOV and the air has already been metered.
Tuning is usually a PITA. I don't recommend using the MAF-T on it's own. Used in conjunction with some other form of fuel controller will afford the best results. An S-AFC or "Jeff O chip" work quite well. The use of a DSMLink has netted the fastest MAF-T cars. Setting the unit up is straightforward.
There are 4 small dip switches and 4 turn dials. The dip switches are (1) sensor type, (2) vehicle, (3) Fuel Cut Defencer on/off, (4) AUX fuel control flat/contoured.
The 4 turn dials are (from left to right) Base: This is a global setting to match injector size to the vehicle. Idle: For your idle correction. Mid: This is mostly for setting your cruise map. WOT: Wide Open Throttle setting. You may find that by setting some of the switches/dials contrary to your vehicle/sensor type, will offer the best tunability. For instance, I use a 3" sensor, yet I have the #1 dip switch set to 3.5" sensor. My car runs better this way. *In other words, don't trust the adjustment given to you. Get a logger, and or wideband.*
Ramchargers is the designer/builder of the MAF-T and the source to get them. *Be carefull when trying to purchase a MAF-T from Ebay, or non-DSM private sale. I have seen a few MAF-T's designed for the Buick Grand National passed off to unsuspecting DSMers. This unit has a different Harness connector with only 3 wires. The unit also has only 2 turn dials. IT WILL NOT WORK ON A DSM!!
Other things to consider in the cost is placement of the MAF sensor. When opting for Blow Through configuration, reducer couplers and a new or modded UICP will be needed. For reference, I spent a total of $500 to install my MAF-T. This included the unit itself, a brand new 3" GM sensor, a custom UICP (which I had my buddy Wes Hess weld up for $90), all the couplers and clamps. Depending on what you do, your bill might be a more or less.
I hope everyone finds this thread informative and helpful to those planning on a MAF-T. Feel free to contact me for any other questions regarding install/tuning.
Here is an extensive list that was braught to my attention. I mentioned a few cars you can scavenge the sensor from. This is pretty much every car that uses it. These can be found readily in any salvage yard across the country.
2003 BUICK CENTURY CUSTOM V6 3.1L 189cid GAS FI N Engine VIN = J
2003 BUICK CENTURY LIMITED V6 3.1L 189cid GAS FI N Engine VIN = J
2003 BUICK RENDEZVOUS V6 3.4L 207cid GAS FI N Engine VIN = E
2003 CHEVROLET ASTRO V6 4.3L 262cid GAS FI N Engine VIN = X
2003 CHEVROLET IMPALA V6 3.4L 207cid GAS FI N Engine VIN = E
2003 CHEVROLET MALIBU LS V6 3.1L 189cid GAS FI N Engine VIN = J
2003 CHEVROLET MALIBU V6 3.1L 189cid GAS FI N Engine VIN = J
2003 CHEVROLET MONTE CARLO LS V6 3.4L 207cid GAS FI N Engine VIN = E
2003 CHEVROLET S10 BLAZER V6 4.3L 262cid GAS FI N Engine VIN = X
2003 CHEVROLET S10 PICKUP V6 4.3L 262cid GAS FI N Engine VIN = X
2003 CHEVROLET VENTURE V6 3.4L 207cid GAS FI N Engine VIN = E
2003 GMC SAFARI V6 4.3L 262cid GAS FI N Engine VIN = X
2003 OLDSMOBILE ALERO V6 3.4L 207cid GAS FI N Engine VIN = E
2003 OLDSMOBILE SILHOUETTE V6 3.4L 207cid GAS FI N Engine VIN = E
2003 PONTIAC AZTEK GT V6 3.4L 207cid GAS FI N Engine VIN = E
2003 PONTIAC AZTEK V6 3.4L 207cid GAS FI N Engine VIN = E
2003 PONTIAC GRAND AM V6 3.4L 207cid GAS FI N Engine VIN = E
2003 PONTIAC MONTANA V6 3.4L 207cid GAS FI N Engine VIN = E
2002 BUICK CENTURY CUSTOM V6 3.1L 189cid GAS FI N Engine VIN = J
2002 BUICK CENTURY LIMITED V6 3.1L 189cid GAS FI N Engine VIN = J
2002 BUICK RENDEZVOUS V6 3.4L 207cid GAS FI N Engine VIN = E
2002 CHEVROLET IMPALA V6 3.4L 207cid GAS FI N Engine VIN = E
2002 CHEVROLET MALIBU LS V6 3.1L 189cid GAS FI N Engine VIN = J
2002 CHEVROLET MALIBU V6 3.1L 189cid GAS FI N Engine VIN = J
2002 CHEVROLET S10 BLAZER V6 4.3L 262cid GAS FI N Engine VIN = W
2002 CHEVROLET S10 PICKUP V6 4.3L 262cid GAS FI N Engine VIN = W
2002 CHEVROLET VENTURE V6 3.4L 207cid GAS FI N Engine VIN = E
2002 GMC S15 SONOMA V6 4.3L 262cid GAS FI N Engine VIN = W
2002 OLDSMOBILE ALERO V6 3.4L 207cid GAS FI N Engine VIN = E
2002 OLDSMOBILE AURORA V6 3.5L 214cid GAS FI N Engine VIN = H
2002 OLDSMOBILE INTRIGUE V6 3.5L 214cid GAS FI N Engine VIN = H
2002 OLDSMOBILE SILHOUETTE V6 3.4L 207cid GAS FI N Engine VIN = E
2002 PONTIAC AZTEK GT V6 3.4L 207cid GAS FI N Engine VIN = E
2002 PONTIAC AZTEK V6 3.4L 207cid GAS FI N Engine VIN = E
2002 PONTIAC GRAND AM V6 3.4L 207cid GAS FI N Engine VIN = E
2002 PONTIAC GRAND PRIX V6 3.1L 189cid GAS FI N Engine VIN = J
2002 PONTIAC MONTANA V6 3.4L 207cid GAS FI N Engine VIN = E
2001 BUICK CENTURY CUSTOM V6 3.1L 189cid GAS FI N Engine VIN = J
2001 BUICK CENTURY LIMITED V6 3.1L 189cid GAS FI N Engine VIN = J
2001 CHEVROLET ASTRO V6 4.3L 262cid GAS FI N Engine VIN = W
2001 CHEVROLET IMPALA V6 3.4L 207cid GAS FI N Engine VIN = E
2001 CHEVROLET LUMINA V6 3.1L 189cid GAS FI N Engine VIN = J
2001 CHEVROLET MALIBU LS V6 3.1L 189cid GAS FI N Engine VIN = J
2001 CHEVROLET MALIBU V6 3.1L 189cid GAS FI N Engine VIN = J
2001 CHEVROLET MONTE CARLO LS V6 3.4L 207cid GAS FI N Engine VIN = E
2001 CHEVROLET S10 BLAZER TRAILBLAZER V6 4.3L 262cid GAS FI N Engine VIN = W
2001 CHEVROLET S10 BLAZER V6 4.3L 262cid GAS FI N Engine VIN = W
2001 CHEVROLET S10 PICKUP V6 4.3L 262cid GAS FI N Engine VIN = W
2001 GMC S15 JIMMY ENVOY V6 4.3L 262cid GAS FI N Engine VIN = W
2001 GMC S15 JIMMY V6 4.3L 262cid GAS FI N Engine VIN = W
2001 GMC S15 SONOMA V6 4.3L 262cid GAS FI N Engine VIN = W
2001 GMC SAFARI V6 4.3L 262cid GAS FI N Engine VIN = W
2001 OLDSMOBILE ALERO V6 3.4L 207cid GAS FI N Engine VIN = E
2001 OLDSMOBILE AURORA V6 3.5L 214cid GAS FI N Engine VIN = H
2001 OLDSMOBILE BRAVADA V6 4.3L 262cid GAS FI N Engine VIN = W
2001 OLDSMOBILE INTRIGUE V6 3.5L 214cid GAS FI N Engine VIN = H
2001 OLDSMOBILE SILHOUETTE V6 3.4L 207cid GAS FI N Engine VIN = E
2001 PONTIAC AZTEK GT V6 3.4L 207cid GAS FI N Engine VIN = E
2001 PONTIAC AZTEK V6 3.4L 207cid GAS FI N Engine VIN = E
2001 PONTIAC GRAND AM V6 3.4L 207cid GAS FI N Engine VIN = E
2001 PONTIAC GRAND PRIX V6 3.1L 189cid GAS FI N Engine VIN = J
2001 PONTIAC MONTANA V6 3.4L 207cid GAS FI N Engine VIN = E
2000 BUICK CENTURY CUSTOM V6 3.1L 189cid GAS FI N Engine VIN = J
2000 BUICK CENTURY LIMITED V6 3.1L 189cid GAS FI N Engine VIN = J
2000 CHEVROLET ASTRO V6 4.3L 262cid GAS FI N Engine VIN = W
2000 CHEVROLET IMPALA V6 3.4L 207cid GAS FI N Engine VIN = E
2000 CHEVROLET LUMINA V6 3.1L 189cid GAS FI N Engine VIN = J
2000 CHEVROLET MALIBU LS V6 3.1L 189cid GAS FI N Engine VIN = J
2000 CHEVROLET MALIBU V6 3.1L 189cid GAS FI N Engine VIN = J
2000 CHEVROLET MONTE CARLO LS V6 3.4L 207cid GAS FI N Engine VIN = E
2000 CHEVROLET S10 BLAZER TRAILBLAZER V6 4.3L 262cid GAS FI N Engine VIN = W
2000 CHEVROLET S10 BLAZER V6 4.3L 262cid GAS FI N Engine VIN = W
2000 CHEVROLET VENTURE V6 3.4L 207cid GAS FI N Engine VIN = E
2000 GMC S15 JIMMY ENVOY V6 4.3L 262cid GAS FI N Engine VIN = W
2000 GMC S15 JIMMY V6 4.3L 262cid GAS FI N Engine VIN = W
2000 GMC S15 SONOMA V6 4.3L 262cid GAS FI N Engine VIN = W
2000 GMC SAFARI V6 4.3L 262cid GAS FI N Engine VIN = W
2000 OLDSMOBILE ALERO V6 3.4L 207cid GAS FI N Engine VIN = E
2000 OLDSMOBILE BRAVADA V6 4.3L 262cid GAS FI N Engine VIN = W
2000 OLDSMOBILE INTRIGUE V6 3.5L 214cid GAS FI N Engine VIN = H
2000 OLDSMOBILE SILHOUETTE V6 3.4L 207cid GAS FI N Engine VIN = E
2000 PONTIAC GRAND AM V6 3.4L 207cid GAS FI N Engine VIN = E
2000 PONTIAC GRAND PRIX V6 3.1L 189cid GAS FI N Engine VIN = J
2000 PONTIAC MONTANA V6 3.4L 207cid GAS FI N Engine VIN = E
1999 BUICK CENTURY CUSTOM V6 3.1L 189cid GAS FI N Engine VIN = M
1999 BUICK CENTURY LIMITED V6 3.1L 189cid GAS FI N Engine VIN = M
1999 CHEVROLET ASTRO V6 4.3L 262cid GAS FI N Engine VIN = W
1999 CHEVROLET LUMINA V6 3.1L 189cid GAS FI N Engine VIN = M
1999 CHEVROLET MALIBU V6 3.1L 189cid GAS FI N Engine VIN = J
1999 CHEVROLET MALIBU V6 3.1L 189cid GAS FI N Engine VIN = M
1999 CHEVROLET MONTE CARLO V6 3.1L 189cid GAS FI N Engine VIN = M
1999 CHEVROLET S10 BLAZER TRAILBLAZER V6 4.3L 262cid GAS FI N Engine VIN = W
1999 CHEVROLET S10 BLAZER V6 4.3L 262cid GAS FI N Engine VIN = W
1999 CHEVROLET S10 PICKUP V6 4.3L 262cid GAS FI N Engine VIN = W
1999 CHEVROLET S10 PICKUP V6 4.3L 262cid GAS FI N Engine VIN = X
1999 CHEVROLET VENTURE V6 3.4L 207cid GAS FI N Engine VIN = E
1999 GMC S15 JIMMY V6 4.3L 262cid GAS FI N Engine VIN = W
1999 GMC S15 SONOMA V6 4.3L 262cid GAS FI N Engine VIN = W
1999 GMC S15 SONOMA V6 4.3L 262cid GAS FI N Engine VIN = X
1999 GMC SAFARI V6 4.3L 262cid GAS FI N Engine VIN = W
1999 OLDSMOBILE ALERO V6 LA1 3.4L 207cid GAS FI N Engine VIN = E
1999 OLDSMOBILE BRAVADA V6 4.3L 262cid GAS FI N Engine VIN = W
1999 OLDSMOBILE CUTLASS V6 3.1L 189cid GAS FI N Engine VIN = M
1999 OLDSMOBILE INTRIGUE V6 3.5L 214cid GAS FI N Engine VIN = H
1999 OLDSMOBILE SILHOUETTE V6 3.4L 207cid GAS FI N Engine VIN = E
1999 PONTIAC GRAND AM V6 LA1 3.4L 207cid GAS FI N Engine VIN = E
1999 PONTIAC GRAND PRIX V6 3.1L 189cid GAS FI N Engine VIN = M
1999 PONTIAC MONTANA V6 3.4L 207cid GAS FI N Engine VIN = E
1998 BUICK CENTURY CUSTOM V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 BUICK CENTURY LIMITED V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 BUICK SKYLARK V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 CHEVROLET ASTRO V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1998 CHEVROLET LUMINA LTZ V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 CHEVROLET LUMINA V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 CHEVROLET MALIBU LS V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 CHEVROLET MALIBU V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 CHEVROLET MONTE CARLO LS V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 CHEVROLET S10 BLAZER V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1998 CHEVROLET S10 PICKUP V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1998 CHEVROLET S10 PICKUP V6 LF6 4.3L 262cid GAS FI N Engine VIN = X
1998 GMC S15 JIMMY V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1998 GMC S15 JIMMY ENVOY V6 4.3L 262cid GAS FI N Engine VIN = W
1998 GMC S15 SONOMA V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1998 GMC S15 SONOMA V6 LF6 4.3L 262cid GAS FI N Engine VIN = X
1998 GMC SAFARI V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1998 OLDSMOBILE ACHIEVA V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 OLDSMOBILE BRAVADA REGIONAL V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1998 OLDSMOBILE BRAVADA V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1998 OLDSMOBILE CUTLASS V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 OLDSMOBILE SILHOUETTE V6 LA1 3.4L 207cid GAS FI N Engine VIN = E
1998 PONTIAC GRAND AM GT V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 PONTIAC GRAND AM SE V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 PONTIAC GRAND AM V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 PONTIAC GRAND PRIX SE V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 PONTIAC GRAND PRIX V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 PONTIAC TRANS SPORT MONTANA V6 LA1 3.4L 207cid GAS FI N Engine VIN = E
1998 PONTIAC TRANS SPORT V6 LA1 3.4L 207cid GAS FI N Engine VIN = E
1997 BUICK CENTURY CUSTOM V6 3.1L 189cid GAS FI N Engine VIN = M
1997 BUICK CENTURY LIMITED V6 3.1L 189cid GAS FI N Engine VIN = M
1997 BUICK SKYLARK CUSTOM V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 BUICK SKYLARK GRAN SPORT V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 BUICK SKYLARK LIMITED V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 CHEVROLET ASTRO V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1997 CHEVROLET LUMINA LS V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 CHEVROLET LUMINA V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 CHEVROLET LUMINA LTZ V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1997 CHEVROLET MALIBU LS V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 CHEVROLET MALIBU V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 CHEVROLET MONTE CARLO LS V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 CHEVROLET MONTE CARLO Z34 V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1997 CHEVROLET S10 BLAZER V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1997 CHEVROLET S10 PICKUP V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1997 CHEVROLET S10 PICKUP V6 LF6 4.3L 262cid GAS FI N Engine VIN = X
1997 CHEVROLET VENTURE V6 LA1 3.4L 207cid GAS FI N Engine VIN = E
1997 GMC S15 JIMMY V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1997 GMC S15 SONOMA V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1997 GMC S15 SONOMA V6 LF6 4.3L 262cid GAS FI N Engine VIN = X
1997 GMC SAFARI XT V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1997 OLDSMOBILE ACHIEVA SC V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 OLDSMOBILE ACHIEVA SL V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 OLDSMOBILE BRAVADA V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1997 OLDSMOBILE CUTLASS GLS V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 OLDSMOBILE CUTLASS V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 OLDSMOBILE CUTLASS SUPREME SL V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 OLDSMOBILE SILHOUETTE V6 LA1 3.4L 207cid GAS FI N Engine VIN = E
1997 PONTIAC GRAND AM GT V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 PONTIAC GRAND AM SE V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 PONTIAC GRAND PRIX SE V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 BUICK REGAL CUSTOM V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 BUICK REGAL GRAN SPORT V6 3.1L 189cid GAS FI N Engine VIN = M
1996 BUICK ROADMASTER LIMITED V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1996 BUICK ROADMASTER LIMITED WAGON V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1996 BUICK ROADMASTER V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1996 BUICK SKYLARK CUSTOM V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 BUICK SKYLARK GRAN SPORT V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 BUICK SKYLARK LIMITED V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 CADILLAC FLEETWOOD BROUGHAM V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1996 CADILLAC FLEETWOOD V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1996 CHEVROLET ASTRO V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1996 CHEVROLET BERETTA Z26 V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 CHEVROLET BERETTA V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 CHEVROLET CAPRICE CLASSIC V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1996 CHEVROLET CAPRICE CLASSIC V8 4.3L 265cid GAS FI N Engine VIN = W
1996 CHEVROLET CORSICA V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 CHEVROLET IMPALA SS V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1996 CHEVROLET LUMINA LS V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 CHEVROLET LUMINA V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 CHEVROLET LUMINA LS V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1996 CHEVROLET LUMINA APV V6 LA1 3.4L 207cid GAS FI N Engine VIN = E
1996 CHEVROLET MONTE CARLO LS V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 CHEVROLET MONTE CARLO Z34 V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1996 CHEVROLET S10 BLAZER V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1996 CHEVROLET S10 PICKUP V6 LF6 4.3L 262cid GAS FI N Engine VIN = X
1996 GMC S15 JIMMY V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1996 GMC S15 SONOMA V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1996 GMC S15 SONOMA V6 LF6 4.3L 262cid GAS FI N Engine VIN = X
1996 GMC SAFARI XT V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1996 OLDSMOBILE ACHIEVA SC V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 OLDSMOBILE ACHIEVA SL V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 OLDSMOBILE BRAVADA V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1996 OLDSMOBILE CUTLASS SUPREME SL V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 OLDSMOBILE CUTLASS SUPREME SL V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1996 OLDSMOBILE SILHOUETTE V6 LA1 3.4L 207cid GAS FI N Engine VIN = E
1996 PONTIAC GRAND AM GT V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 PONTIAC GRAND AM SE V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 PONTIAC GRAND PRIX SE V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 PONTIAC GRAND PRIX GT V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1996 PONTIAC GRAND PRIX GTP V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1996 PONTIAC TRANS SPORT V6 LA1 3.4L 207cid GAS FI N Engine VIN = E
1995 BUICK REGAL CUSTOM V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1995 BUICK REGAL GRAN SPORT V6 3.1L 189cid GAS FI N Engine VIN = M
1995 BUICK ROADMASTER ESTATE V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1995 BUICK ROADMASTER LIMITED V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1995 BUICK ROADMASTER V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1995 CADILLAC FLEETWOOD BROUGHAM V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1995 CADILLAC FLEETWOOD V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1995 CHEVROLET CAPRICE CLASSIC V8 4.3L 265cid GAS FI N Engine VIN = W
1995 CHEVROLET IMPALA SS V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1995 CHEVROLET LUMINA LS V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1995 CHEVROLET LUMINA V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1995 CHEVROLET LUMINA LS V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1995 CHEVROLET MONTE CARLO LS V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1995 CHEVROLET MONTE CARLO Z34 V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1995 OLDSMOBILE CUTLASS SUPREME SL V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1995 OLDSMOBILE CUTLASS SUPREME V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1995 OLDSMOBILE CUTLASS SUPREME SL V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1995 OLDSMOBILE CUTLASS SUPREME V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1995 PONTIAC GRAND PRIX SE V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1995 PONTIAC GRAND PRIX GT V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1995 PONTIAC GRAND PRIX GTP V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1994 BUICK REGAL CUSTOM V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1994 BUICK ROADMASTER ESTATE V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1994 BUICK ROADMASTER LIMITED V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1994 BUICK ROADMASTER V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1994 CHEVROLET CAPRICE CLASSIC V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1994 CHEVROLET CAPRICE LS V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1994 CHEVROLET CAPRICE CLASSIC V8 4.3L 265cid GAS FI N Engine VIN = W
1994 CHEVROLET CAPRICE CLASSIC LS V8 4.3L 265cid GAS FI N Engine VIN = W
1994 CHEVROLET IMPALA SS V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1994 CHEVROLET LUMINA EURO V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1994 OLDSMOBILE CUTLASS CIERA SL V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1994 OLDSMOBILE CUTLASS SUPREME S V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1994 OLDSMOBILE CUTLASS SUPREME V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1994 OLDSMOBILE CUTLASS SUPREME S V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1994 OLDSMOBILE CUTLASS SUPREME V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1994 PONTIAC GRAND PRIX SE V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1994 PONTIAC GRAND PRIX SE V6 3.1L 189cid GAS FI N Engine VIN = M
