General How to tell if your injector are maxed out?
select fuel injector duty
MMCD - labeled IDC (injector duty cycle - hit 101 last night... gotta step up to 650's)
mine measure 82% at 7K RPMS at full boost (17PSI) i wanna replace mine but wont do it if im still in a safe enough margin...
Mits3gts said:
oh man! I am hitting 120-122 when full boost kicks in. Stock everything, except a few minor bolt-ons. Is something wrong?
Injectors CANNOT flow more than 100%. What you are logging is what the ECU WANTS the injectors to do. At 100%, the injector is open all the time, which is not good. Above 90%, injectors get erratic. That's why most suggest 85% as max. The injector needs to open and close to flow properly. You need to turn down your boost.
even though the car is pretty much stock? only mods i have are uicp and 2.5 turboback,i still have the stock boost controller hook up..will a fuel pump rewire help me out with this?
Did you log ipw and convert it yet or are you still just looking at idc from mmcd? No one can help you if youm dont really have any problems.
